Old 01-30-2005, 12:46 PM
eddies eddies is offline
fuel pump problems again?
Please help!! does anyone know where the fuse for the fuel pump is on my 93 s10 blazer 4.3 vortec? I have already changed the relay and the pump is not running when the key is turned on.Is there a fuse at all? Also the pump was just replaced last march, could it have failed so soon?Any help would be greatly appreciated.....
Old 01-30-2005, 02:10 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: fuel pump problems again?
Could have popped early if it was defective.
I would take it back to where you had the work done, it should be under warranty.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-30-2005, 03:09 PM
Re: Re: fuel pump problems again?
I changed the pump myself so theres nobody to take it back too.Do you know if there is a fuse for that pump? thanks..
Old 01-30-2005, 03:34 PM
BlazerLT's Avatar
AF -Advisor
Check the fuse panel for a fuel pump fuse, it may be there but I doubt it.
The pump should still be under warranty.
There should be a grey wire in the engine compartment to prime the pump.
Old 01-30-2005, 04:29 PM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
Is your fuel pump aftermarket (lifetime warranty) or OEM-AC Delco (1 yr warranty)? If aftermarket, yes it can go bad so soon. The part might be warrantied but they don't pay for labor! I did my fuel pump on my truck 3 weeks ago, I bought aftermarket as well but have been kicking myself in the #&& since then. Plan On taking it back and getting the OEM (with only 1 yr warranty) for $30 more. Why? Because AC Delco designed that pump for that vehicle and there is a pat. on it so any aftermarket parts cannot ever be as good as the original, otherwise the aftermarket co.'s would get sued by GM
Old 01-30-2005, 05:09 PM
BlazerLT's Avatar
AF -Advisor
Either way, he pump should be under warranty.
