Old 01-30-2005, 01:26 PM
mother_russia mother_russia is offline
Amp Mounting
Can I mount my amp directly to my 3/4 inch thick fiberboard sub box? in the box is a jl 10w6 at 300 rms so it will likely rattle the box a lot. are the vibrations going to screw up the amp or rattle loose the connections? i am all ready to install now, with the box nearly done, and i suddenly realized that this may be a problem a second ago. shit.
Old 01-30-2005, 07:03 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
yes, if your box is vibrating bad enough to ruin your amp .... you need to rethink your box build
Old 01-30-2005, 07:53 PM
sorry, my question was, WILL it vibrate enough to ruin the amp? i wouldn't say the box is dancing around, but its obviously giving the amp a good shake. i was thinking about maybe putting a thin layer of some sort of styrofoam or insulator sweezed between the amp and the box to help reduce it. and, it might be fine anyway. i got to opinions locally, both guys thought it would be fine. we'll see.
Old 01-31-2005, 01:09 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: Amp Mounting
I don't know how well you box is built so I can't say. If the bax is strong you should have no problem mounting on box but if the wood virbates and shakes a lot don't do it
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
