Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 01-30-2005, 12:17 PM
lambodog lambodog is offline
Tight turning problems 99 Expedition
When turning right or left, wheel bog down, don't turn; growling sound. Had power steering fluid checked and OK. Only happens on hard rights or lefts. What might this be? Thanks. 1999 Ford Expedition.
Old 01-30-2005, 01:14 PM
yotermanic yotermanic is offline
Could be a power steering pump. Listen under the hood while someone turns the wheels for you.
Old 02-24-2005, 02:01 PM
skiphunters5 skiphunters5 is offline
tight steering
try going in gravel and turning, loose gravel, if it doesn't bog down when you turn and bogs down when you turn on dry pavement then you are stuck in 4 wheel drive other than that i don't know
