Old 01-30-2005, 11:18 AM
mbrownab mbrownab is offline
1996 problems w/pwr widows
Our '96 is having problems. when changing the Interior light bulb a screwdriver by acident touched somthing now the Int. lights dont work and the power windows dont work.. I have looked at the fuses, and they are good. any Ideas how to fix this problem is much appreciated!! TY in advance !!
Old 01-31-2005, 03:22 AM
Please!!
Anybody Please???
Old 11-21-2005, 11:24 PM
woodz_4 woodz_4 is offline
Re: 1996 problems w/pwr widows
The same thing happened to me just a few days ago if you find out how to fix this please let me know Thanks.
Old 11-22-2005, 07:19 AM
TomV TomV is offline
Cool
You must have blown a fuse somewhere. Check those in the engine compartment as well.
Old 11-22-2005, 08:13 PM
DLH1 DLH1 is offline
If you are certain that the fuses are OK, try disconnecting the battery for a few minutes. This may re-program the body computer. This might help. If you do this, follow the owner manual for idling the engine after you reconnect.
Old 11-22-2005, 09:09 PM
KimMG KimMG is offline
AF - Advisor
How did you check the fuses? Did you use a test light or a meter?
Old 11-22-2005, 09:49 PM
Cool Re: 1996 problems w/pwr widows
Fuses to check include:
#1 Choice = Passenger compartment Fuse 27 Battery Saver relay
#2 Choice = Under hood Fuse 4 Power Locks
Old 11-25-2005, 09:19 PM
Re: Re: 1996 problems w/pwr widows
i used both and all of them work
Old 11-25-2005, 09:29 PM
AF - Advisor
Use a wiring diagram to trace all the affected areas and see if you can find a common point of failure.
There may be a burned up plug or wire caused by the short.
