Old 01-30-2005, 08:49 AM
CR50HC CR50HC is offline
Vibration during acceleration
Hi folks. My steering wheel shakes during acceleration. What kinds of things could cause this?
Old 01-30-2005, 09:28 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: Vibration during acceleration
are your tires alligned and balanced?
does it always shake on only at or after certain rpms???
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-30-2005, 09:56 AM
I just had the tires balanced and it didn't change anything as far as the vibration during acceleration. I beleive the vibration is always there throughout the RPM range. I haven't had an alignment done. Could it be a motor mount? They were not changed during my motor swap from the D15B2 to my DOHC ZC. I would like to figure this problem out.
Old 01-30-2005, 10:02 AM
midrange midrange is offline
Send a message via MSN to midrange
Could also be Wheel bearings or tie rods if you feel it through steering wheel. Maybe a worn ball joint. I don't think it would be a motor mount if its more of a constant small vibration. Motor mounts are clunking noises usually
Old 01-30-2005, 10:09 AM
Interesting. Seems like I can hear a slight "clunk" if I am at a dead stop in the parking lot and turn the steering wheel right and take off from a dead stop, I hear what appears to be something in the front right suspension slightly "clunk". I've checked the CV axels (only 4 months old). There's no tears in any boots, leaking grease etc... I do have a bit of metalic "buzzing" sound in the gear shift at certain RPMS which led me to think possibly an engine or even a tranny mount? The tie rods are new as well. I'm stumped..... Also looking to do the HF final drive conversion on the ZC tranny to get better gas mileage on the highway... Should I sniff out this vibration problem first?
Old 01-30-2005, 10:41 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
sounds to me like the front bars that connect to the front chassis bar....looks like this:
Either your front chassis bar is loose (it's held on by 4 bolts) or one of the bars has come loose.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 01-30-2005, 10:46 AM
amy@af's Avatar
Re: Re: Vibration during acceleration
eh, kinda. i busted a mount. didn't hear any noises. busted a 2nd, same thing. busted a 3rd mount and it felt like i busted an axle. it very well could be a bad mount. you can visually inspect them to see if they are torn.
our 93 integra has a bad mount. it vibrates pretty good...curses to the dohc (lol)
for a balljoint you can sit directly infront of the tire and try to shake it side to side. if the tire has much play then your balljoint is bad. you will also hear the tire wobble when you hit a bump.
check your mounts and take it from there....
Old 01-30-2005, 11:30 AM
Sounds good. I'll check the balljoint and then peek the front bars. Now, I'm no mechanic I'm an audio and electronics guy so can you be a little more detailed on which bars to check? I'm capable of checking for loose bolts and tightening them though.
Old 01-30-2005, 11:44 AM
amy@af's Avatar
i think he's talking about the radius rod?!?! pictured here:
the suspension section: http://www.binghamtonlife.com/manual...suspension.htm
service manuals: http://www.binghamtonlife.com/manual/manual.htm
Old 01-30-2005, 01:19 PM
You folks are so awesome! Thanks! I'll print this and put the Rex on the jack stands and see what I can find out. Hope to get it figured out soon!
Old 02-02-2005, 09:34 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
what about axels? they clunk when you turn and could cause a vibration if they are bad enough...check for torn boots
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 02-02-2005, 09:42 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
i have almost the same problem - i got my tires balanced and got an alignment, and it doesn't vibrate as bad but when i brake and sometimes during acceleration it can vibrate plenty. I'm probably going to replace this suspension soon...and fix all these problems within the next few months.
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 02-02-2005, 10:33 PM
The axels are 6 months old. Suspension was replaced with Tokico Blues (spring and strut kit) I have the factory steelies. I'm leaning toards the radius rod right now. Funny though... it's raining here today and she rides smooth as silk. Could this be a tire balance problem? maybe the water on the roads is providing a bit of a cushion from the vibration? This is weird.....
Old 02-03-2005, 07:37 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
You are more in tune with your ride now. I get all nervous when I'm on a bumpy road when the steering wheel shakes. I have to tell myself it's just the road... when I first moved to SC the roads were awesome... smooth as silk... but 12 years later and enough SUVs to alter the Earth's topography, it feels like I'm driving in NJ... ugh! Anyway, you may want to check your tire pressure... you should do it monthly.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
