Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 01-30-2005, 07:48 AM
ntt ntt is offline
Del sol vti problems
Hi..
I have a del sol 1.6 vti `93.
I`m having problems with the vti.
When the engines rpm go over 5.500 it starts to choak and doesn`t run smooth at all. I already head the car checked by local honda garage, but all they did was driving arround and wondering wath it was.
If the engine is pushed for a while it starts to run smoother, almost normal, but still the rpm needel tweches and turns off the scale...
Had anyone had that problem and what could be wrong...
thanx
ntt
Old 01-31-2005, 01:16 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: Del sol vti problems
5,500 rpm's is where your VTEC engages. If it's choking at the activation point, you may have issues with your VTEC solenoid or something else related. Have you gone to the Honda dealership or just a local shop?
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 01-31-2005, 08:13 AM
ntt ntt is offline
Re: Re: Del sol vti problems
i`ve been to the local honda dealer, and they checked it out. They didn`t find anything wrong, not even the computer check showed results... all they did was driving(racing) arround and it was ok for a month or so. Then it slowly starts again...
P.S.: excuse my english
Old 01-31-2005, 12:06 PM
Re: Re: Re: Del sol vti problems
I'd say it's probably a sensor somewhere. Might want to try resetting your ECU and do the basics to make sure - spark plugs, wires, fuel and air filters, oil, fuel injector cleaner, valve adjustment, and fuel injector cleaner.
If none of the above solves it, probably going to be a sensor somewhere that's giving you problems. Might be the VTEC solenoid - that's my first guess. I'm no expert though, so perhaps someone else has an opinion?
Old 02-01-2005, 09:10 AM
ntt ntt is offline
Re: Re: Re: Re: Del sol vti problems
Thanx... I`ll check what you mentioned above, although i fixed all the basics allready...
Old 02-02-2005, 09:28 AM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
sounds like something electrical with the VTEC solenoid... like Jon said.... Just as a piece of advice, you said after it's driven around for a while it smoothes out.... you shouldn't be pushing it over like 4500 until the engine is warmed up. You can do damage... that may even be what your problem is now. Do you know how much a new b16 block from the honda dealer is? I do!
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 02-02-2005, 06:28 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
What kind of oil are you running. If it is really cold, your oil my be to thick to engage VTEC. Remember VTEC uses oil pressure to engage the third rocker arms. After it warms up, the oil becomes thinner. Just a thought.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 02-04-2005, 11:47 AM
ntt ntt is offline
Don`t wory I always warm up the engine...
Ok I know oil is importaint, so which do you recomend...
Old 02-05-2005, 04:08 PM
I would use mobil one in evrything, since it is so easy obtainable, but if i had the patience, i would run leading edge or amsoil. They are two of the best. Honda's tend to burn oil at high RPM's to protect the rings, so swithching to synthetic may cause excessive oil burn off. I switched in my sol at about 125,000 miles and it burnt mobil one like no tomorrow. If you run into this also, run castrol GTX high milage. Hands down the best organic oil on the market in my opinion.
