The Case of the disappearing Oil
I have a 99 Silhouette with the 3.8L V6. About 2 1/2 months ago, I had to start adding oil. Approximately one quart every three weeks. There are ZERO symptoms. It idles and accelerates well. The plugs are not fouled. The compression is 175 psi, near perfect. There are no drips, there is no spray on the underbody. There is no smoke. There is no excessive carbon in the tailpipe. Where is the oil going?
Don't know and would like too. My 2001 OLDS Silouette is using a lot of oil too. Would like to have a clue before I talk to a mechanic.
Oil loss
One possibility is the oil is entering the coolant. GM V6 engines have a high failure rate for intake manifold gaskets. This would make the orange Dexcool appear milky. We had the gasket replaced under warranty two years after buying our van.
Re: The Case of the disappearing Oil
99 with 3.8L ??
Valve stem seals?
A quart every 3 weeks is possible depending on your driving mileage. The oil gets by the valve end seals, then by the vlave guides into the combustion chamber where it's burned. How many miles do you have on the engine. I have about 160K and recently had to replace a head gasket, the valves were leaking as were the valve seals, did a valve job and all is well. Try a heaver weight oil and see if it helps. Good luck Let us know what happens. 94 |
Re: Oil loss
Re: Re: The Case of the disappearing Oil
jimmy is right i had the same problem with a 2001 silo that i have and the oil was gettin by the valve seals the dealer put a new motor in for me told me it was shot if i were u sell the piece of crap ive put a new motor and trannyin mine and it only has 134 kms the vans are junk |
Re: Oil loss
Re: Oil loss
Re: Oil loss
I just got a new fuel level sending unit from P&G for $86.40 + S&H - list is $150.26. Bill is very pleasant person to deal with. Al |
