Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 01-30-2005, 04:55 AM
QuarterMile QuarterMile is offline
Send a message via AIM to QuarterMile
Cutting the springs..
I have to ask one other thing, my buddy who I think is a dumb ass says that you can cut your springs to your car and it wont effect it and the drop will be fine. I told him he is a dumb ass but, he thinks he is right, am I wrong or is he right, I just want to know so tommrow I can let him see this lol.
Old 01-30-2005, 07:26 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: Cutting the springs..
If you cut the springs now you have a spring that is not coiled properly and will affect your ride quality as well as your ride height. You also risk blowing out your shocks if you don't replace them with something aftermarket to withstand the new pressure on your suspension created by lowering the car's center of gravity and to keep the car from rolling too much in turns now that you have half a spring to support the same OEM shock that was designed for a full spring.
Hope that helps clear it up. In short, get new lowering springs and shocks or some decent coilovers if you want it done correctly.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 01-30-2005, 10:47 AM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
exellent responce fork. I agree 110%. It can be done, but is definately not a good idea.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 02-02-2005, 09:21 AM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
^^ What they said. I've seen it done in a pinch for shows, but guess what... 500 miles later the shocks blow right out from under him. Take your time, save up your money, and do it right. It will cost you less in the long run.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
