Go Back   Automotive Forums Car Chat > Ford > Galaxy
Old 01-30-2005, 03:08 AM
benswolf_1's Avatar
benswolf_1 benswolf_1 is offline
Send a message via AIM to benswolf_1 Send a message via Yahoo to benswolf_1
67 galaxie problems
Ok,
I have a 2dr 67 galaxie 500 with a 390. I just had the original 2v carb and intake swapped for a 4b edlebrock and high pro intake manifold. He re-jetted the carb and tweaked it as good as he could. He said it was hard to get it perfect because it is so cold here right now. Anyways when i get on the gas hard i here a click and there is a delay like im not even on the gas then it reacts and takes off-my problem is that i am going to race it this spring/summer and that delay will kill me-so what might be the problem? Thanks!
-Ben
Old 04-17-2005, 04:22 PM
TommySS TommySS is offline
Re: 67 galaxie problems
Sounds like an accelerator pump problem
Old 11-02-2005, 09:09 AM
deske deske is offline
hi i have to change my timebelt for a 1.9tdi galaxy year 2000 anyone got a manual for this???
Old 11-02-2005, 09:23 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Re: 67 galaxie problems
Stat a new thread on this subject and you will get a better response.
Old 11-09-2005, 11:32 AM
hxgaser hxgaser is offline
How big is your carb? Is your motor built? Although 390 is a big block, stock motor ususlly works around 500 to 600 cfm range at the most. You might be flooding it. Try it with smaller jets.
Old 04-22-2006, 06:52 AM
Aremy Griese Aremy Griese is offline
if the cam is bad, it'll make a snapping sound when you give er. but if the cam is good , then the guy who did your carb f-ed up. cause that engine can handle well over a 600cfm, even stock. other then that , all i can say is check your timming again.
aremy
Old 07-31-2007, 08:59 PM
dakota9991 dakota9991 is offline
i have the same problem i have 289 4 v [600cmf] with duel piont dist .with mechanical advance it has a nice cam an headers on take off it,s a dog but once rolling it shots off it also has a stock coil iam lost also the car runs great if you drive it normal maybe some one can solve both our problems
