Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-30-2005, 01:48 AM
redtegb18b1 redtegb18b1 is offline
Send a message via AIM to redtegb18b1
440cc injector injector ?
ok now i need to double check and make sure that RC 440cc saturated injectors with HIGH RESISTANCE Approx. 12-16 OHMS measured at 43 P.S.I.G. will work w/a b18b1 non vtec. thanks
Old 01-30-2005, 11:57 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: 440cc injector injector ?
What are you upgrading for? Turbo, Nitrous?
2002 Acura TL Type S
1991 Honda Crx Si
Old 01-30-2005, 12:34 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
you should not be concerned on how much you'll boost on the injectors. you should be concerned with it's duty cycle. resistance should be 10-13 ohms.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-30-2005, 09:02 PM
it is for a boost application. i'm am using a smaller turbo (t25) and i'm probably gonna run 10psi at the max and prob 6 psi for daily driving so i was just makin sure those would do the trick. thanks
Old 01-31-2005, 10:13 AM
Heres some info on Injectors and such a did awhile back. Should help you to understand some things.
Injector Info
1991 Honda Crx Si
Old 01-31-2005, 12:00 PM
Kven's Avatar
Kven Kven is offline
whether theyll work or not will depend on the ECU you're using(but most likely yes they will work since OBD1 cars used high impedence)
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 01-31-2005, 12:31 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
440cc's should be able to handle up to 300whp, maybe a tiny less.
Team Lonely Drivers
Old 01-31-2005, 12:59 PM
AF - Advisor
what are you using to control the injectors?
Old 01-31-2005, 09:23 PM
i will be using the apexi s-afc
