Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 01-30-2005, 01:27 AM
bambam2000 bambam2000 is offline
Fuel Supply System
I got a check eng code 43 FUEL SUPPLY SYSTEM
and I was wondering what that consists of. my set up is a h22a turbo for the fuel i'm runnig an fmu, aem fuel rail, sfc field boxer controler. what going on rigth now is that every time I give it full throtle is leans out and at the same time my sfc goes into "of" mode instead of delivering more fuel
Old 01-30-2005, 09:23 PM
boytiti's Avatar
boytiti boytiti is offline
Re: Fuel Supply System
so there you go, you just answered your own question. your ecu is unable to conpensate for the lean A/F mixture at full throttle, therefore you get CEL code 43. you need to re-progs your ecu look-up table. that means the values need to be changed to higher numbers until you get rich running condition on full throttle. moding your shit takes a lot of trial and error until you get it right.
My WebSite
Old 01-30-2005, 10:57 PM
but hte thing is that my sfc doesn't want to do the job even if i add just 1% more at each rpm if just doesn't do it, it goes into "of" mode. do you think the sfc is bad or the ecu is bad or what?
