Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 01-29-2005, 11:45 PM
Michael2000 Michael2000 is offline
2000 Continental Door Panel Removal, Water Leak
Water enters the cabin of my 2000 continental at the bottom of the door panels every time it rains. Does anyone have this problem ?
I have tried unsuccessfully to remove the door pannel. I removed the 5 crews (two in the door handle, two at the bottom under the map pocket, and one on the side) but I still cannot pull it out. Are there push pins to be removed ?. I will appreciate any hints.
Old 11-03-2005, 12:26 PM
jmclark2000 jmclark2000 is offline
Re: 2000 Continental Door Panel Removal, Water Leak
I have the same problem with my '00 Continental, did you find anything out about the problem?
Old 07-06-2009, 09:24 PM
mach1diesel mach1diesel is offline
There are four or five clips you have to pop out around the edges of the door. It would be a good idea to buy the door panel removal tool (available at any auto parts store). Take care to not break the clips, as you will need to reuse them afterwards.
