Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 01-29-2005, 11:43 PM
ddrdh4 ddrdh4 is offline
Unhappy 95 Riv, antifreeze filling plenum
I have 95 Riviera that antifreeze is being sucked into the plenum and then into the cylinders. I just replace the gasket with a new one and it's still doing the same thing. Does any one know the tork setting for tighting the plenum bolts? Or has any one had a problem with this that requires something other than new gaskets?
Thanx for the help!
Don
Old 02-18-2005, 03:45 PM
chalkman chalkman is offline
Standby for a new intake manifold, if your issue was like mine. Ended up losing anti-freeze, into the cylinders. Replaced the gaskets, same problem. After round 2, took very close look at the intake and found problems with the EGR passage; it had actually melted the plastic intake! I replaced it with a new GM intake and no more problems . This happened about 4 years ago, and I think I have the old intake and can send a photo if you want me to.
Old 03-02-2005, 11:56 AM
Re: 95 Riv, antifreeze filling plenum
I found the problem the heat of the EGR tube had melted the plastic plenum and water was being sucked into the engine in the intake. I had to replace the Plastic plenum and it no longer leaks.
