Old 01-29-2005, 09:34 PM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
No spark
I checked power to the coil and its hot. But I am getting no spark from the coil. Can anyone help me out with what to check. Its a 92 3 cyllinder metro. Thanks
Old 01-30-2005, 07:54 AM
geojim geojim is offline
Re: No spark
Could be as simple as a coil gone bad.
But, I would first take off your distributor cap and crank the engine to see if the rotor turns. Turning is good, not turning indicates a broken timing belt.
1993 Geo Metro - 1.0, MT, A/C - 343K Miles
Old 02-01-2005, 09:43 PM
jake1ekaj jake1ekaj is offline
Dude, I just went through the whole ignition rigumarole. Here's what I learned. They coil wires resistance should be 3.0k-6.7k ohms per foot. It just so happens that the cable is about a foot so check if that might be your problem.
Check your coil too. Measure the resistance of the primarys (between the 2 small leads) 1.08-1.32 ohms and check the secondary (from the 1 small to the coil output) 22.1k-29.9k
If you don't have a multimeter, an auto parts store can test it for you as well. The coils are pretty pricey too. One of the guys here recommended the MSD Blaster SS. Auto zone was the cheapest I found.
Good luck.
JAke
