Go Back   Automotive Forums Car Chat > Honda > Odyssey
Old 01-29-2005, 09:13 PM
cm2boys cm2boys is offline
Question 2002 Odyssey automatic door problem
One of my automatic doors is having problems closing. It gets about 95% closed and then I hear the humming noise but instead of the normal short humm it just continues for several seconds and never clicks shut. Also the LED light for the door stays on. To make the door fully shut I have to lean on the door from the outside. Nothing is obstructing the bottom track. Any ideas? thanks.
Old 01-30-2005, 04:48 PM
lorunner lorunner is offline
Re: 2002 Odyssey automatic door problem
Try cleaning the contacts in the door jams first. The pins get corroded and don't make contact. Us a pencil eraser and clean them and try it again.
For really bad pittting and tarnish i use a scotch bright pad. works well too.
Old 01-31-2005, 10:23 AM
Smile Re: Re: 2002 Odyssey automatic door problem
Thanks so much!!! Cleaning the contacts fixed the problem. I didn't think they looked that dirty but when I used the eraser it made the contacts a shiny metal finish. Honda should put this fix in the manual.
Old 01-31-2005, 04:03 PM
But then people would never bring it in to get it fixed and we would be out of work.
Stop asking me about radio codes I cant get them anymore!!!
Old 02-03-2005, 02:47 PM
stevetatro stevetatro is offline
There's also a procedure to get the doors to "re-learn" their travel. It involves pulling a fuse (#13?), manually opening the door all the way, reinstalling the fuse, using the interior door buttons to close the door (I think you hold the switch down until it's 100% closed).
This is all from memory. It's been discussed on the Forums at www.odyclub.com extensively.
1993 Ford SHO
Red/Black 181k miles
2001 Honda Odyssey EX
Green/Tan 62k miles
1999 Isuzu Rodeo LS
Black/Gray 77k miles
Old 02-03-2005, 03:52 PM
Right but there isn't any need unless the door throws a code and stops working completely.
Old 02-22-2005, 02:08 PM
jaylang jaylang is offline
Post Re: Re: 2002 Odyssey automatic door problem
I have a 2000 EX. When the passenger door stopped working, I checked the fuse and contacts. Nothing seemed to work until a few weeks later when I changed the battery, the door started working again. I replaced the battery because it was five years old and the car didn't seem to start as easily as usual.
Old 08-09-2007, 02:59 PM
ruggb ruggb is offline
been having problems with this for a long time on my 2000. Sometimes it works mostly not. Just disassembled it for the 2nd time. Opened up the cover with the plastic gear. Only had to bend one tab. Gear looked fine, no broken teeth or wear.
I put it back together placing the gear in a different position than it was.
So far it works fine with repeated closing.
keep my fingers crossed.
