Old 01-29-2005, 09:06 PM
billbertreed billbertreed is offline
Angry NEED HELP getting off Transmission Oil Fill Plug!
1989 lx 5sp sedan. There is something in the way and I can't get my ratchet in there! I have a 17mm attachment for the ratchet, the fill hole is the 17mm size right? and the drain is the 3/4 in. ratchet head. Do I need to remove the thing (spedometer box or something?) that's in the way of the fill or do I need a better wrench? This is so frustrating! Help out a young brotha!
Old 01-29-2005, 09:49 PM
88CiViC_D-15's Avatar
88CiViC_D-15 88CiViC_D-15 is offline
Send a message via AIM to 88CiViC_D-15 Send a message via MSN to 88CiViC_D-15
Re: NEED HELP getting off Transmission Oil Fill Plug!
speedometer box?? it should be above the drain plug on the pasanger side of the car. and i belive its a 17mm, but could be wrong.
Team Lonely Drivers IS LOOKING FOR MORE MEMBERS,CLICK HERE
TLD FOURMS
- 88 civic std w/ sohc zc swap
- 88 integra ls, stock
- lookin for a 4dr. runnin or not
Old 01-29-2005, 09:58 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the transmission plug is located behind the fender lining on the passanger side. just remove that and you'll see the plug
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-30-2005, 01:00 AM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
fill through VSS
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 01-30-2005, 01:30 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Originally Posted by Jos4DCivic
fill through VSS
I tried to do this it takes 4ever. It is a 17mm use a box end wrench to get it off. At least on mine there is not enough room to get a scocket in there.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 01-30-2005, 09:41 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Why would anyone fill through the VSS? I would imagine using that would overfill the tranny. Check here GL
Old 01-30-2005, 11:03 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Re: NEED HELP getting off Transmission Oil Fill Plug!
you can fill thru the vss. how would you overfill? if you know the amount that's supposed to be in there....then only pour that amount in there. I believe its 1.7 qts. It's actually more accurate than filling it at the overflow plug because you con't know what angle your car is on.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 01-30-2005, 01:16 PM
Jos4DCivic's Avatar
yeah its about 1.7-1.8.
91 Hatch SI
Finally painted!!!
Old 01-30-2005, 07:12 PM
johnb16a2's Avatar
Re: Re: Re: NEED HELP getting off Transmission Oil Fill Plug!
OK, so my logic was mis-placed (I'm using the same logic as filling the tranny through the fill hole). But the sentiment is the same, why use the VSS hole because isn't there some clip or what not that can fall into tranny if not disassembled properly? Not to mention the risk of dirt falling in...
BTW, when I removed the plugs on my car I used a breaker bar and my foot to break them loose. I'm happy to report that I got the proper amount of oil in it and it runs great.
Old 01-31-2005, 11:22 AM
bambam89lx's Avatar
AF - Advisor
look in the honda manual. They tell you to fill it thru the vss. That plug that you're using to fill it is called the "overflow plug". You open that and fill thru the vss. When it starts to pour out, you have the right amount.
Old 01-31-2005, 04:10 PM
Re: Re: Re: Re: NEED HELP getting off Transmission Oil Fill Plug!
Is the VSS the little, straw-sized hole above the tranny? I think there are two bolts next to it. And also, what is a breaker bar and how do you use it? I couldn't for the life of me get the 17mm bolt off there with a box end wrench. It just wouldn't budge.
Old 01-31-2005, 04:23 PM
Cjz89civic's Avatar
AF Premium User
yes it is the one your Speedo cable goes into. Watch out for the clip that holds the cable into the tranny.
Old 01-31-2005, 09:07 PM
Projekt_Si Projekt_Si is offline
Send a message via AIM to Projekt_Si
I just got done filling up a new tranny on my 89 Si hatch. Yes. it is a 17mm. No. the socket won't work. it's too big. use a standard 17mm wrench to get the bolt off. Now... the best way to fill it it to use one of those pump-n-spray things. you know the kind for bug spray and shit? thats it. a funnel is a pain in the ass. just fill it till a little starts to pour out and tighten the bolt up.
Old 02-01-2005, 02:23 PM
johnb16a2's Avatar
Re: Re: Re: Re: Re: NEED HELP getting off Transmission Oil Fill Plug!
A breaker bar is just a long handle with a attachment on the end to accept a socket. If you don't want to go out and buy one you can just put a pipe extention on your regular ratchet. All to get extra leverage.
I did mine a while ago and now I remember I also used a 17mm box end wrench. However, I did cheat a little in that you can lock another box end wrench to the 17mm and made my own breaker bar that way.
But if you don't want to mess around with the fill plug you can do what others have suggested and fill though the VSS. I have the offical Honda and Haynes manual and neither mention using the VSS hole to fill the tranny. Check here
GL
Old 02-01-2005, 04:55 PM
Thanks everybody. I tried using the 17mm box end but it just wouldn't budge. I will try to lock another box end on to the end to get some more leverage. If that doesn't work, I'll be forced to try and fill through the VSS. I won't get a chance to work on it for a few weeks though, but I'll update when I try again.
gunmetal 89 lx 5 sp, cromed out
enhanced performance from custom K&N air filter installation
est. hp gain: 30 hp
makes the whoooooooooosh sound that we all know and love
K&N performance oil filter, ultimate filtering. hp gain=15hp
K&N sticker inside engine bay (stay clean and sleeper)
Regular Chevron w/ techron additive for performance enhancement. "ulimate additive." hp gain=5-6 hp
Price?: Priceless
Interior?: Clean
'nuff said
