Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 01-29-2005, 08:33 PM
83lincolnlimo 83lincolnlimo is offline
No fire when starting on 83 TownCar
I have an 83 TownCar that is not starting. I have replaced the ignition module, the ignition switch, the ignition coil, the plugs and wires. I have power to the coil. When I start the car, I have tested good voltage to the coil, but I have no spark. If I pull the wire from the coil to the distributor and test for power, I receive no power to the wire until I release the key. For that one moment, I see a single spark. I have electronic ignition (no wires go to the distributor). Do I need to replace the ECU (computer), or is something else not telling the coil what to do?
Regards, Rob
Old 01-31-2005, 09:14 PM
Towncar's Avatar
Towncar Towncar is offline
Sounds like the 60's and 70's with a blown ballast resistor
I don't have diagnosis experience with the 83.
Try LOL if you get no response here.
-Steven
1996 Town Car, Cartier
Old 02-03-2005, 11:11 PM
I do not think it is the ballast resistor, since I am still receiving power to the coil when I am turning the key. I have pulled the ECU, and will most likely replace it. Does anyone know where I can by an 83 lincoln towncar ECU?
- Rob
Old 02-17-2005, 06:43 PM
Re: No fire when starting on 83 TownCar
Update: I have fixed the problem! I found out that the EEC Relay was fried. Once I replaced the EEC Relay, the car fired up immediately. I found out that I could put back the original crankshaft position sensor and the ECU (computer). I have left the other replaced parts in place.
- Rob
