Old 01-29-2005, 06:00 PM
DA HULK DA HULK is offline
92 blazer problem
i just got a 92 s10 blazer and the is something wrong with something. the problem is that when you go to shift into drive or anything for that matter nothing happens as far as going forward or in reverse. so i guess my question is what might the problem be or were should i start to attack this problem. thanks for any help... signed newbie
Old 01-29-2005, 09:02 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Sounds like the transmission is shot or at the very least has no fluid in it. Check your fluid levels (while the truck is running) And put in enough transmission fluid to bring it to proper levels. If that doesn't work, the tranny is probably toast and you should look into getting a used one or a rebuilt one. (Note: your tranny is a 700r4)
Old 01-29-2005, 09:47 PM
tom3 tom3 is offline
With shifter in neutral can you push the car back and forth? Could be a shifter arm off? Odd to have no forward or reverse at all. Does driveshaft turn?
Old 01-30-2005, 12:16 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 92 blazer problem
Take the truck back immediately.
The transmisison is shot.
1995 Factory Blazer Service Manual for sale, PM if interested.
