Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 01-29-2005, 04:55 PM
thomybob1 thomybob1 is offline
Question Changing engine from standard trans to automatic Will it work
I have a geo with a rough body and a good motor. I found a good body with a bad motor. Mine is a standard shift and the other one has an automatic. Will my motor work in it? (They are close to the same year model,1991)
Old 03-06-2005, 01:21 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Changing engine from standard trans to automatic Will it work
You should just be able to swap out the flexplate for the flywheel.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
