Old 01-29-2005, 05:39 PM
uter12345 uter12345 is offline
Need Help car over heating
i have a 96 2.2 L a cav and it over heats. Well first i notice their was air in system and i took it out. so it was fine for a couple days,, and again their was air in the lines so i let it out by unsrcrewing the breather. and also changed the thermostat. But Again some how im getting air in the line causing the care to overheat. iF THEIR IS NO AIR THE CAR IS FINE. HELP HELP. Thanks
Old 01-29-2005, 07:58 PM
planedude planedude is offline
Re: Need Help car over heating
Is the car running good? Sounds like a head gasket, these cars are prone to this issue. Run the car with the overflow cap off and see if you can see bubbles in the resevoir.
Old 01-31-2005, 01:19 PM
car
car runs fine the gauge goes up side to side every 5 to 10 min. didnt run the car yet witrhout the rad cap but i will. but if its the head gasket isnt coolant supposed to be leaking out of the side?
Old 02-01-2005, 01:34 AM
depends where tthe gasket breaks, if its in the combustion side it will put air in your system...
Old 02-03-2005, 04:49 AM
Mangoamerican Mangoamerican is offline
Send a message via ICQ to Mangoamerican Send a message via Yahoo to Mangoamerican
i had the same problem, and changed the gasket (there wasnt any breaks in it) but i had a new one anyways.. so i put it in.. only to find out it didnt help the air/heating problem.. im going to have my head pressure checked, cleaned and checked for warpage.. hopefully that will give my car back its compression so i can friggin start it
