97 Blazer Codes - Update
hey all,
I posted a question about a problem I was having with my 1997 Blazer a while back. After driving the vehicle for a while, when I start driving up hill, SOMETIMES, I seem to lose power (very sluggish) and I would get a blinking check engine light. Once I cleared the hill the problem would go away and the light would clear. I just got the vehicle codes scanned and got 2 codes. PO0300 and PO0303. My #3 cylinder also recorded 4383 misfires. Now, I'm assuming this is some kind of ignition problem, but I just replaced the cap/rotor, plug wires and plugs. Unfortunately, I did not know when I did the plugs that AC Delco Platinums were recommended and was told that his could be part of the problem. (just put normal Bosch's in) Anyways, any input would be greatly appreciated. I want to get this problem solved before I have to start pulling the boat around in the summer again. Thanks in advance, Phil Last edited by psawatsky; 02-08-2005 at 10:28 AM. |
Re: 97 Blazer Codes
The check engine light comes on when the PCM sees something it doesn't like. It flashes when the problem is a major concern such as a possible catalytic converter failure.
The code P0300 is a random misfire code, the P0303 tells you that #3 cylinder is the culprit. It could be a spark plug wire, plug or injector. I would take a good close look at the plug. Knowing how easy it is to get to, it may have been cracked during installation. If you can duplicate the problem, try swapping the plug with one cylinder and the wire with another. If the misfire stays with #3, you've elimated the wire and plug. If it moves, the moved part is the problem. |
Re: 97 Blazer Codes
[A flashing MIL light indicates a type A misfire. This means that the catalytic converter is at a high risk for damage. If your tune-up did not cure the problem, it could be injector related, either not firing, or stuck open. I would have an injector balance test done if the tune-up was not at fault.
Re: Re: 97 Blazer Codes
Tuneup is in order. BIGTIME
1995 Factory Blazer Service Manual for sale, PM if interested. |
Thanks for all your replies. I will look into a couple things. I meant to ask a question in my last post, but obviously missed it.
Have any of you heard of the Blazer needing the AC Delco Platinum plugs to run properly?? As I said before, I did a tune-up but only used normal Bosch plugs. Could this be what is causing my misfire?? If not, I had read somewhere else that there was some sort of recall on 97 Blazers for their injectors?? Something like under 100,000 miles, but I might be mistaken. Anyways, Thanks again, Phil |
Re: 97 Blazer Codes
OH GAWD, Remove the Bosch's immidiately!
They have been known to cause the misfire in our trucks. Go with AC Delco Plats ONLY and stay away from the others. The AC Delco Plats are great plugs. AC Delco Performance Standard Platinum: http://search-desc.ebay.com/41-932_W...trypageZsearch AC Delco Performance Platinum Rapidfires: http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW Buy them off of ebay, incredibly CHEAP!
Alright, so now I've done the tune-up, put in the right plugs (AC Delco Platinums) and seem to have everything running better, but I can still feel a misfire when under heavy load. I'm assuming it is still the #3 cylinder and I'm assuming it is injector related.
A while ago, I read a post that quoted this : "The injectors on the vortec from 1996 to 1999 have a bad habit of sticking and causing a missfire code p300, Chevy came out with a TSB they are replacing them under warranty if cleaning doesn`t correct the problem,up to 10 years or 100k miles." Does anybody know if this is true?? If not, where should I go from here? Thanks |
Re: 97 Blazer Codes
TSB #00-06-04-003B 1995 - 2002
Chevy says to clean the injectors and replace if there is still a problem. They say that the customer will pay for it. |
File In Section: 06-Engine Emissions
Bulletin No.: 99066F Date: March, 2003 SPECIAL POLICY SUBJECT: 99066F - SPECIAL POLICY ADJUSTMENT - SEQUENTIAL CENTRAL PORT FUEL INJECTION (SCPI) FAILURES IN CALIFORNIA ONLY (YF5 EMISSION EQUIPPED) MODELS: CERTAIN 1996, 1997, 1998, 1999, 2000, 2001, 2002 S/T, M/L, C/K, G, P, W4/NPR TRUCKS AND 2003 NPR TRUCKS EQUIPPED WITH 4.3L (RPO L35 - VIN CODE W OR RPO LF6 - VIN CODE X), 5.0L (RPO L30 - VIN CODE M) OR 5.7L (RPO L31 - VIN CODE R) ENGINE AND CALIFORNIA EMISSION EQUIPPED (RPO YF5) This bulletin is being revised to add the 2002 and 2003 model years to the SCPI Special Policy on certain S/T, M/L, C/K, G, P and W4/NPR truck models. Please discard Special Policy Bulletin Number 99066E, dated February, 2003. CONDITION Some customers of 1996, 1997, 1998, 1999, 2000, 2001, 2002 model year S/T, M/L, C/K, G, P, W4/NPR trucks and 2003 NPR trucks, that are registered in California, equipped with 4.3L (RPO L35 and VIN Code W, or RPO LF6 and VIN Code X), 5.0L (RPO L30 and VIN Code M) or 5.7L (RPO L31 and VIN Code R) engine, and California emissions (RPO YF5), may experience a "Service Engine Soon" light, misfire, rough idle or hard start due to a deposit build-up on the Sequential Central Port Fuel Injector (SCPI) poppet valve(s). The deposit build-up may cause injector poppets to stick closed. Certain fuels have been found to interact with the SCPI system to cause the deposits. SPECIAL POLICY ADJUSTMENT This special policy covers the SCPI failure condition described above for a period of ten (10) years or 200,000 miles, whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership. The repairs will be made at no charge to the owner. This special policy applies ONLY to repairs requiring SCPI system servicing, injector cleaning and/or MFI assembly replacement of the SCPI system. The customer should not be charged for performing a system check when it is determined that the SCPI system is not the cause of a customer complaint (labor operation T5532 is provided to submit claims for such system checks). Any additional necessary diagnosis and repairs that are not related to the SCPI condition are not covered by this special policy. The customer should be informed that any further service that is not covered by new vehicle warranty will not be covered by this policy. VEHICLES INVOLVED Involved are certain 1996,1997,1998,1999, 2000, 2001, 2002 S/T, M/L, C/K, G, P, W4/NPR and 2003 NPR model vehicles, registered in California, equipped with 4.3L (RPO L35 - VIN Code W, or RPO LF6 - VIN Code X), 5.0L (RPO L30 - VIN Code M) or 5.7L (RPO L31 - VIN Code R) engine; and California emissions (RPO YF5). This Special Policy covers all vehicles within these model years, with these engine and emissions RPO's. PARTS INFORMATION Parts required to complete this special policy are to be obtained from General Motors Service Parts Operations (GMSPO). Please refer to your "involved vehicles listing" prior to ordering parts. Normal orders should be placed on a DRO Daily Replenishment Order. In an emergency, parts should be ordered on a CSO = Customer Special Order. IMPORTANT :Isuzu Parts Ordering: In order to comply with the 10-digit Isuzu part numbering system, Isuzu dealers must add an "8" to the beginning and a "0" to the end of the listed 8-digit part numbers when ordering parts through AIPDN. CUSTOMER NOTIFICATION Customers will be notified of this special policy on their vehicles by General Motors (see copy of typical customer letter included with this bulletin - actual divisional letter may vary slightly). SERVICE PROCEDURE System Check: Use strategy-based diagnoses listed in the front of the Driveability and Emissionssection of the service manual. If the SCPI system is operating properly, inform the customer that the vehicle does not have the condition listed in the owner letter. If poor driveability conditions persist, inform the customer that any further diagnosis and repairs will be at their expense if the vehicle is outside the parameters of the new vehicle warranty. SCPI Injector Cleaning Procedure: If diagnosis leads to sticking poppet nozzles, use the service procedure from Service Bulletin 00-06-04-003B to clean the SCPI poppet nozzles. Please note that the service bulletin term for SCPI is Central Sequential Fuel Injection (CSFI), but is referring to the same fuel system assembly. If the poppet nozzles have previously been cleaned and the sticking condition has reoccurred, refer to the correction paragraph below. SCPI Fuel Tank Fill Pipe Assembly for 1997-99 M/L Van and 1999 - some 2000 C/K Truck: with 4.3L, 5.0L, 5.7L engines and built prior to listed VIN/Production dates on Service Bulletin 00-06-04-018: If diagnosis leads to sticking poppet nozzles on these models, use the service procedure from Service Bulletin 00-06-04-018 to replace the fuel tank fill pipe assembly, if this procedure has not been performed previously. Previous service procedure can be verified by checking GMVIS for Labor Operation L1065 on "M/L" trucks with replacement part number 15050573; or Labor Operation L1065 on "C/K" trucks with replacement part numbers 15747585 or 15747588. Correction: If, after cleaning the SCPI poppet nozzles, the normal service manual diagnosis still indicates that the SCPI is the cause of the customer complaint, or if the injectors have previously been cleaned and the vehicle has again experienced sticking poppet nozzles, refer to Service Bulletin 00-06-04-003B and replace the SCPI fuel assembly with the MFI fuel assembly. Please note that the service bulletin term for SCPI is Central Sequential Fuel Injection (CSFI), but is referring to the same fuel system assembly. CLAIM INFORMATION For vehicles repaired under this special policy, submit a claim with the information indicated. CUSTOMER REIMBURSEMENT Customer requests for reimbursement are for any previously paid repairs to, or replacement of, the Sequential Central Port Fuel Injection (SCPI) system. Repairs must have occurred within 10 years of the date the vehicle was originally placed in service, or 200,000 miles, whichever occurs first. The requests are to be submitted within two (2) years of the date on which the repair was paid or within two (2) years of the date of this Special Policy Bulletin, whichever is greater. When a customer requests reimbursement, they must provide the following: - Proof of ownership at time of repair. - Original paid receipt confirming the amount of unreimbursed repair expense(s) (including Service Contract deductibles), a description of the repair, and the person or entity performing the repair. Customers from the State of California, must submit requests for reimbursement directly to (Divisions) per instructions in the owner letter. If the work was done by someone other than a GM dealership, the amount of reimbursement will be limited to the amount that the repair would have cost GM to have it completed by a GM dealership. |
Re: 97 Blazer Codes
Get the codes checked and see which cylinder is misfiring.
Run a good fuel injector cleaner through the system to clean the gunk keep the valve open.
Re: 97 Blazer Codes
Special Policy 99066F is for California Emissions only. The rest of us are out of luck.
Re: 97 Blazer Codes
have a 2003 chev 4.3L blazer 80k miles with the same random misfire problem. felt fortunate just to get the thing back home. have been reading many blogs indicating this problem over a several year span. chevrolet should be ashamed for putting stuff like this on their customers for so long!!!
