Old 01-29-2005, 03:45 PM
mistysymons mistysymons is offline
Angry Grand Prix SE 92 Door
Inside the door panel something has broken and I am unable to open the door from the inside and outside. I am unable to yet find away to get the panel off. I can't open tht door at all. thanks
Old 01-30-2005, 04:13 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Grand Prix SE 92 Door
Well unfortantly you need to get the door panel off to manually pull the release rod inside the door to open it. There are usually plastic cover tabs on pontiacs covering bolts on the door panel that must be removed to get the panel off, Also the speaker frame holds it on and at the bottom of the door usually has plastic snaps that hold it in place. Good luck and welcome to AF.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-02-2005, 01:44 PM
martygunn martygunn is offline
I just had to do this a month ago. There are two main screws holding the inside panel on. both are behind the inside door pull. The heads of them are torxs so you'll need a star bit. The other things holding on the panel are plastic tabs all around the outside.
