Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-29-2005, 12:45 PM
92RS 92RS is offline
'94 SL-1 SOHC ----- Aftermarket Gauges???
I am using a 94 saturn SOHC in my project car (not a saturn) and am wondering where to connect a tach and possibly an oil pressure gauge.
The RPM signal wire at the coil packs seems like a likely connection but i don't know if that would affect the signal back to the computer. I also know the SOHC motor has only an oil pressure switch and not a pressure sender and the switch is threaded into a port that is rather large. Is there a boss somewhere that can be drilled and tapped or another connection point that would have been used on an SL-2 (same block as far as I have heard) that is somehow blocked off?
Thanks for the help,
Jay
Old 01-30-2005, 09:20 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: '94 SL-1 SOHC ----- Aftermarket Gauges???
oil pressure(most people i know remove the stock pressure switch and put it there) - http://www.kallistimotorsports.com/t..._oil_press.pdf
i'm not sure of the tach, try saturnspot.com.
what are you puting the engine into?
Old 01-30-2005, 09:42 PM
The engine is currently in a 1972 Volkswagen
http://www.geocities.com/anticpunk for details on that.
and thank you for the sources, I'll check those out.
-Jay
