Old 01-29-2005, 12:27 PM
h22hatch91 h22hatch91 is offline
Post 5th gear problem
i just did a b16 motor swap and when i drive around or whatever it will automaticly slip out of 5th gear and go into neutral. it seems it only slips when the car has been running for a while because if i go into my car right now and go out and drive it would be fine until a little while after the motor has warmed up then it will continue to slip. any idea on what is causing it to slip out of 5th ? .............thanks
Old 01-29-2005, 01:56 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
sounds like it could be bad syncro. does it grind at all going into 5th?
if the car jumps out gear into neutral,particularly when decelerating or going down hills,first check the shift lever and internal gearshift linkage. excessive clearance between gears and the input shaft or badly worn bearings can cause jumping out of gear. other internal tranny parts to inspect are the clutch pilot bearing,gear teeth,shift forks,shift rails,and springs.
Good luck
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
