Old 01-29-2005, 10:21 AM
77chrome 77chrome is offline
Spark Plugs.
Hey Just wondering what you guys thought the best plugs and wires to buy for my car. I know NKG are the best but witch ones should I get. Also, do you think that lightweight pullys are a good mod?
Old 01-29-2005, 12:22 PM
Igovert500's Avatar
blue + red light magnet
Re: Spark Plugs.
http://johnmonnin.netfirms.com/PlugWires.html
has a nice comparison
Essentially, as far as I'm concerned it depends if you are modded or not (do you have a vr4?)
Unless you have a vr4 and are turning the boost up higher than stock levels, I would stick with NGK platinums, as they last longer and are great plugs.
If you turn up the boost, and are having issues with spark blowout, I'd go copper, but then you have to change them every 10k. If you have an NA, then just go with what you like, I'd still recommend platinum, as they are cheap, reliable and such. But you could also check out the stuff on john monnins website and on stealth316, and do some research on iridiums and see how you like those...but once again, I don't think anything beats the NGK platinums plugs.
As far as the pulleys...there is a constant debate about this...
http://www.pacarsearch.com/stealth/udp.htm
that describes the debate pretty well. personally I wouldn't do it on a vr4, as there are plenty of other ways to get hp. If you have an NA, then possibly, if you are running out of mods to do...but I still don't like the idea of them. Just my .02, but check out the websites, and make your own informed decision.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-30-2005, 12:59 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Re: Spark Plugs.
Originally Posted by Igovert500
[ I would stick with NGK platinums, as they last longer and are great plugs.
agreed
Originally Posted by Igovert5hundredmillionbagillion
I'd still recommend platinum, as they are CHEAP, reliable and such.
wow there cowboy. maybe i've fallen off my horse, but last time i checked, platinums were anything but cheap. if you're lucky, you can find a set of 6 plugs for about $60. but expect to pay at least that and most likely close to 70 or 80. but yes, the NGK Platinums are really good and last a long time.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-30-2005, 02:14 AM
Hotshot8792 Hotshot8792 is offline
Re: Re: Re: Spark Plugs.
Originally Posted by Linebckr49
agreed
yea, platinums are a bit more expensive. You have 3 types of plugs, copper, platinums, and iridiums. Coppers are the best conductors and produce the most possible power, and i would recommend them on a turbo car, but you have to replace them every 10K miles as stated. They are also the cheapest as they are $1.89 a piece at your local auto store. The platinumbs a bit more expensive at about $10 per plug. They are the second best conductors of electricity, but last quite a bit longer then coppers, probably up to 35 or 40k miles. And then last you have iridiums which are the most expensive, about $15-$20 per plug but supposedly last probably around 60K+ miles, but are the worst conductors of electricity of the three.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 01-30-2005, 04:24 AM
Linebckr49's Avatar
Re: Re: Re: Re: Spark Plugs.
if Iridiums are the worst conductors of the three, then would someone only purchase them for their longevity? is the difference in performance (copper, plat, irid) negligible or noticeable? it seems the jump in price is only due to each plugs lifespan and totally unrelated to performance.
93 3000GT base
Old 01-30-2005, 11:01 AM
Igovert500's Avatar
Whoops, thanks for catching that. My mistake.
As far as price being due to performance and longevity...I think of it this way...boosted cars are the antithesis to normal cars. In a normal car, their performance differences are negligable (as far as I'm concerned) and the main draw is the less they have to be changed the better. For turbo cars however, we need the extra power of the spark emitted from the copper plugs and we need to combat spark blowout. So power is more of a concern for us. Luckily most of the general public wants longevity and doesn't care about the conductivity of the plug as long as it works for them. So it ends up working out that we get the plugs we want for cheap. Unfortunantly, we do need to change them more often...but it's not like we don't enjoy being under the hood anyway, so it isn't a big deal as far as I'm concerned.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-30-2005, 11:36 AM
exactly, and if you think changing spark plugs that often is a pain in the butt, then you shouldnt be modding your car to that point where you need the coppers to help overcompensate for spark blowout. I can have all 6 of mine changed out within 30 minutes, so its not like its that hard.
Old 01-30-2005, 02:09 PM
Linebckr49's Avatar
Re: Spark Plugs.
thanks guys. in no way was i complaining about changing plugs; i love being under the hood, and actually, i'd rather change them before every 10k miles...just so i can rip off the plenum more frequently. but thanks for clearing that up. i do see it makes more sense to think of plugs in terms of naturally aspirated cars, and forced induction cars.
93 3000GT base
