Old 03-14-2002, 10:07 AM
Wallythecat Wallythecat is offline
Question Windhield Washer Pump
I recently picked up a 95 civic and, after inking the deal and signing the paper stating everything worked to my liking and the dealer wouldn't be held responsible for any parts etc... I noticed the windshield washer pump doesn't work.
I checked the fuses and it was fine. I replaced the pump and still nothing. I checked the wire socket and it doesn't appear that power is getting to the pump... Anybody have an similar problems or know where to begin looking for problems? I can trace the wire back to the firewall but feel apprehensive about tearing a bunch of stuff apart to find the problem...
Old 03-15-2002, 12:14 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
Try running the wire direct to the fuse and see if that works. Also ground the black wire onto metal on the car. If that works then it's something through the wiring that is either cut, touching wires together, or touching metal. Good luck finding the problem.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 03-15-2002, 07:19 AM
It was the plug... I ended up bending the connectors a bit, plugged it back in and it works! I must not have grounded my tester properly when I was checking for current... Either that or there was so much dirt and stuff in there I couldn't reach the connectors...
Thanks for your help!
Old 03-16-2002, 10:23 PM
1995HondaCivic's Avatar
1995HondaCivic 1995HondaCivic is offline
Send a message via AIM to 1995HondaCivic
if you need a new pump, want to buy mine? its in the basement.
Old 03-16-2002, 11:10 PM
brandonf brandonf is offline
try another fuse
