Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 01-29-2005, 12:34 AM
DELaSol DELaSol is offline
Need Help pickin out rim size n suspensions
Duuudddeess.. help me decide wit a problem i have.. I want to get an rims measuring at 18x7.5 front & rear.. n im prob gettin the WORK japanese rims http://www.worksuperwheels.com/wheels/emotion_cr.html.. will it fit on my del sol? and if it did.. would there be any kind of friction between the tyres n fenders? n wot tyre size would be ideal? a fren recommends gettin a 225/35 for all 4 cos its prob d max it could handle bearing in mind d del sol is a FWD 1.6 litre engine and having bigger tyres would mess up d speedo.. or would it be easier gettin a 17' rims but ill prob hate myself for not gettin an 18'.
Suspensions is another problem im having.. my frens keep on mentioning top brand names like TEIN or EIBACH n SKUNK2 and all but ive always known that the best suspension for a Honda is NEUSPEED. so wot would u guys think if i get the NEUSPEED Coilover Suspension? its got 4 specially manufactured Neuspeed springs and a set of 4 threaded-body Bilstein Shocks.. Lowers approx. 0.75 - 2.5 (F) & 0.75 - 2.5 (R).. sweet aye?
so wot do u all think? should i get a 17' or 18'? is the NEUSPEED Coilover Suspension good enough for a daily driven car?
Old 01-29-2005, 02:56 AM
Vtec'dDelSol Vtec'dDelSol is offline
Well first off, I wouldn't go any bigger than 17s on a Sol. But thats my opinion. If you do want 18s and that drop you'll probably have to roll your fenders. I have 17s and eibach sportlines, and im barely clearing fender. Oh and don't forget if you do drop it that low, replace your struts with shorter ones for that drop, or they will blow. But in all, those are all nice lowering springs, I wouldn't go with coil overs. or 18s. but everyone has their opinions.
Old 01-29-2005, 06:24 PM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: Need Help pickin out rim size n suspensions
get damn 16s.... there is no reason to have 17s on a sol... I have 17s on right now and I hate them. Can't wait to get my 15s back.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 01-30-2005, 03:01 AM
thanx for d quick reply.. hahaha n emily.. theres a reason y girls look so cuuuttee on del sol's.. its cos of those nice 15' rims hahahaha
im not gonna lower ot all d way nooooooo.. may 1.5' at d rear n just a few more inches lower at d front.. would have had nightmare wit potholes if i were to drop it all d way..
but 17' is not bad but 18' is weeelll.. bigger! haha so wot say d rest?
Old 01-30-2005, 07:16 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
First off, the Jamaican accent is wierding me out.
Second, I personally wouldn't go larger than 16". I'm more for performance than show, however, so whatever floats your boat. Based on what I know from other people's posts on other boards, you'll have a hard time with 18"s and risk rubbing. You're better off staying with 17" or smaller. Just hope you're not planning to race. You'll have a hard time launching 17"s or 18"s with the small amount of torque the B16A has to begin with.
And honestly, anything larger than 16"s on a Honda looks silly IMO. I roll on 15"s.
As for suspension, Neuspeed, Tein, Eibach, or Skunk2 should all be fine. Just don't buy cheap or you'll regret the poor quality. I'll be installing Tein on mine in the future, but you can install whatever you like.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 01-30-2005, 10:52 AM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Yep, 18's are a bad idea unless you are building a show car. with the low profile tires (tyres for you ) you run the risk of creating bubbles in the sidewall over bumps. I would hate having to dodge every bump in the road. You will actually be hurting peformance too. 16's are the best for the civic chassis. I have 15's also, but am planning on 16s.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 02-14-2005, 10:33 AM
spoonsleeper's Avatar
spoonsleeper spoonsleeper is offline
just get some 16" rims with 45 series tires and if your only gonna drop it 1.5", then don't waist your money on coilovers, just get some Eibach pro-kit springs
Old 02-20-2005, 01:37 AM
Thanx for the suggestions..
I went with a very light 17 inch racing wheel by WORK Wheels and just had a B20 block installed but stil using my B16A head but gonna change it to a B18C5 as soonas i can find one. and daaaammmmnn.. it picks up verrryyy ffaasstt..
i also went with the coilovers cos my shocks are almost wearing off so decided with a full suspension replacement using neuspeed. and added a skunk2 front and rear strut bars and handles like a dream.
next thing i wanna do now is change d stock manifold and throttle body. i wanna use the type r manifold cos its a bit larger than d stock manifold but i dun wanna use d type r throttle body. im thinking of gettin a tommei throttle body for nissan's s15 cos its got a wider diameter but doest that mean i have to use nissan's TPS sensor too?
Old 02-20-2005, 02:10 PM
94SolGrl's Avatar
stop... with.... THE (not "d").... fake.... rastafari... CRAP.
~*Emily*~
HOW TO POST PICS!
Old 03-08-2005, 10:04 AM
bigtex713 bigtex713 is offline
Send a message via ICQ to bigtex713 Send a message via AIM to bigtex713 Send a message via Yahoo to bigtex713
real quick 17's are a nice size
/\\/|Imorts are killers on the streets|\//\
want to race me?!? lol thats funny cause yall lose. i might be new at this but i got some skill.[this is all a joke so dont act stupid about this]
\\95' eclipse gst\\
\\\DOHC manual\\\
\\\\stock turbo\\\\
\\\\\every thing else is stock\\\\\
\\\\\\\coming out to play\\\\\\
Old 03-29-2005, 06:48 PM
vemulasri vemulasri is offline
for me 16" sounds gr8. 17" s are great too but you have problem with clearance i would recommend 16"s. But then again its just my opinion
