Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 01-28-2005, 11:51 PM
MichiganOutdoors MichiganOutdoors is offline
1998 Sonoma No Electrical at all...
Nothing works...no dash lights, no headlights...Nothing...Was backing out of the driveway and it just quit.
Any Ideas before I get it towed and pay and arm and a leg?
THANKS!
Old 01-29-2005, 11:14 AM
Re: 1998 Sonoma No Electrical at all...
No one on here can help?
Old 01-29-2005, 11:32 AM
84fiero123's Avatar
84fiero123 84fiero123 is offline
you say nothing works, does horn work? also check fuses alll, everything is fused. then check battery connections and battery to make sure battery didnt explode or short out, most likely the problem with as cold as it has been in the northern part of the country, if battery froze same may have happened
Old 01-29-2005, 09:08 PM
keithchevy keithchevy is offline
Re: Re: 1998 Sonoma No Electrical at all...
my buddys 2001 sonoma just quit running the guages were going nuts cranked but wouldnt start. on engine a rubber hose burned through from exhaust gas and burned up some wires in engine harness
Old 01-30-2005, 10:48 PM
I put a new battery in it and connections were tight...Nothing worked at all...didn't check the horn but had it towed to the service station yesterday. They didn't start work yet so any heads up so I know they don't fix something that isn't broke and charge me an arm and a leg would be appreciated....THANKS!
Old 01-31-2005, 06:31 AM
blazee's Avatar
blazee blazee is offline
Problem?
I wish I would have seen this post yesterday. Your problem is probably the fusible link between the battery and the battery distribution block.
Old 02-01-2005, 02:04 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Does anything work on this truck?
Radio? Starter?
1995 Factory Blazer Service Manual for sale, PM if interested.
