Old 01-28-2005, 11:01 PM
stlwagon stlwagon is offline
Strut Tower Brace
Just ordered a Speedbuilt front STB for my 99 GTP. Any thoughts on if I should do the rear as well?
Old 01-29-2005, 12:17 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Strut Tower Brace
Hey Wagon,
I would.
Old 01-29-2005, 01:04 AM
Thanks Kid. Man you're up late. Would it improve handling that much more over doing just the front?
Old 01-29-2005, 08:57 AM
Re: Re: Strut Tower Brace
Just don't buy the ones off Ebay. Was talking with John, said a few people he knows did. Rust city.
Which ones you going to use?
Old 01-29-2005, 09:07 AM
BIG-L's Avatar
BIG-L BIG-L is offline
In his first post he said Speedbuilt
You should order both bars and save some bucks.
You wount feel ahole lot of difference ive had the Next Level which are the same as speedbuilt from the grandprix store,for handling your better off going with larger sway bars front and rear.GMpartsdirect offers a kit 34mm front sway, 19mm rear sway,larger trailing arms and a front stru tower brace for about 150 bucks shipped.
~Larry~
ClubGP Member 6530
Since 2001
Old 01-30-2005, 12:57 AM
Already ordered the front from PFYC. Will likely do the back when I find the time. I looked at the handling kit on GMpartsdirect. May also do that down the road. So many parts...so little $$.
Old 01-30-2005, 02:33 PM
KX2000GTP KX2000GTP is offline
I was told by a fellow Club GP membe that STB don't do anything beneficial to our cars...is this true? and if not, what benefit would it server?
Old 01-30-2005, 03:42 PM
BIG-L's Avatar
Yes.
The only time you really need STB's are NASCAR, Road Course's or Auto Xing,going at high rates of speed thru the corners,which helps with chassie flex.STB's have no effect on handling.But they sure look nice under the hood
You wount feel ahole lot of difference,ive had the Next Level which are the same as speedbuilt from the grandprix store,for handling your better off going with larger sway bars front and rear.GMpartsdirect offers a kit 34mm front sway, 19mm rear sway,larger trailing arms and a front strut tower brace for about 150 bucks shipped.
ClubGP Member 6530
Since 2001
Old 01-31-2005, 08:47 AM
carnutcass's Avatar
carnutcass carnutcass is offline
Originally Posted by BIG-L
Yes.
Orrrrr........if you're like me and take the highway "Clover-leaf" off-ramps at 60mph!
I have the Next Level on the front and a GM Parts Direct (Buick Regal GS) STB on the rear. The rear was more noticable than the front. Think about the rear......there's no significant sheet metal between the rear strut towers. The front at least has the firewall.
Buick Regal GS STB. Can't go wrong for $16!!
