Old 01-28-2005, 09:59 PM
Diceman83's Avatar
Diceman83 Diceman83 is offline
Send a message via AIM to Diceman83
Box shape
OK, I've read just about every thread dealing with boxes, sealed vs ported, bandpass, etc. For my listening tastes, I think I've decided on a sealed enclosure, mainly because I prefer SQ over loudness. I know, it's a little different than most people, but that's me.
However, I've only seen a little bit comparing cubic shaped vs tubed enclosures, and I was curious about the advantages and disadvantages of each. I was also wondering about hybrid designs, with say, a smallish cube just big enough for the sub with a big PVC pipe embedded in it to bring up the total volume. Please don't flame me, I'm a beginner at this stuff, and I don't really know the do's and don'ts of this art. Also, what about 3D orientation? Does the sub have to point directly back or can it be pointing up or sideways? I know forward is bad, so that direction is out. Ideally I'd like to take some of the space in the back behind one of the wheel wells so I can still use most of my trunk.
I'd like to build something interesting to look at that sounds good from the frequencies of like 20 Hz to like 200 Hz (or where ever the midrange speakers start to take over). I don't really want to go totally loud like most of you guys do (no offense), so sound quality over the whole range at lower volume levels (like less than 100 dB) is what's important to me. I have some nice 3/8" lexan I'm planning to make at least one side out of, for a window with some lights .
As far as what I have to work with: I got a decent deal on a used Rockford Fosgate 15" hx2 sub (with the 4 ohm dual VC's) and a Soundstorm F500.2 amp. I know these aren't the best stuff out there, but it's what I can afford. Being able to get like 400 Watts out of $160 isn't too bad I would think. I have a '93 Honda Accord EX sedan, with a good Panasonic head unit and some pioneer coax mids.
Sorry this is so long, but these are the questions I have after reading for like 3 days.
Summarized:
  • speaker box: square vs tube (hybrid?)
  • cone orientation: straight back vs up, sideways, etc
  • frequency range?
Thanks guys!
Old 01-28-2005, 10:37 PM
AndonD454's Avatar
AndonD454 AndonD454 is offline
Send a message via AIM to AndonD454
Re: Box shape
not an expert just giving my 2 cents..
as far as i knwo there is really no difference between round enclosures and square ones. I would think that the only thing that matters is volume. shape probably doenst have an effect. most people build boxes because theyre easy. therefore, i doubt a hybrid would even do anything except take up volume in your box. i would suggest just an MDF box. or a fiberglass box if you cant get one done.
as far as where to point your subs.. it depends on your car. i wouldnt suggest firing them to the side. ive heard a car liek this and it wasnt good. most people fire them back, but you might want to try flipping a box around back there and seeing what sounds best.
and the frequencies.. yeah youll need sealed to get the range you want. hoewver you wont get good responce from your sub at 200 hz trust me. most people have their mids take over at like 60-90 hz.(i think) mine are at like 80. how good are those infinities? i doubt your midbass will be very strong, but id say 80-90 hz would be good.
the sub is ok, but more meant for getting loud. actually from what i remember this sub had very poor sound quality, but youll figure that out after you get it in your car and listen to it for a while.
is your amp a 2 channel? im assuming its only stable down to 4 ohms bridged.. problem there being you cant wire your sub for 4 ohms. you would haver to wire it to 8 ohms and then youd really only be getting like 200 watts to your sub. dont knwo the specs on either sub or amp but may want to look into this.
if you end up haveing to get rid of one or the other, ditch the sub and check out an atlas 15 from ascendant audio (www.ascendantaudio.com) BUT.. get back with us first about whether that amp will work with the sub.
1996 Explorer 4.0 V6 4x4
Sold all my shit.
waiting for more money
Old 01-28-2005, 11:10 PM
Diceman83's Avatar
Re: Box shape
ok, the sub is rated as follows:
Frequency Range: 24-200 Hz
Dual 4 ohm voice coils rated to 300 Watts each
Q factor: 0.53 Qts (quarts?)
Recommended Box volume: 2 - 5.5 ft^3
amp specs:
Input level adjustment
Line level & speaker inputs
Freq resp (+/- 3 dB): 9 Hz - 50 kHz
Variable low pass crossover: 40 Hz - 150 Hz
High pass crossover
THD @ RMS output: .01%
Variable Bass Boost: 0 - +18dB
S/N ratio: 103 dB
Channel separation: 90 dB
Power MAX 2W 500W x 2
Power RMS 4W 200W x 2
Bridged Power 1000W x 1
Damping Factor 125+
I was thinking about hooking the connections up in parallel so it's a 2 Ohm woofer and just using a single channel on the amp. That way it's using 500 watts of the rated 600 watts, which is close enough for me. I could also use both channels in 4 ohm mode for a total of 400 watts. I guess either way would work.
It's going to be a few months before I can actually install and test this, because it's so freakin cold outside. (it's -5 degrees F at the moment) I would like to build the box anyway, and maybe if there's a mid winter thaw, I could install it then. Luck favors the prepared, I guess.
Anyone have a response to "box shape doesn't matter as much as total volume enclosed"?
Old 01-28-2005, 11:56 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: Box shape
do you already have the equipment? I would suggest different things for a sq setup.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 01-29-2005, 12:20 AM
Diceman83's Avatar
Re: Box shape
I know there are tons better things out there, I'd just like to get the best sound possible from 160 bucks worth of stuff. I do already have the equipment, and I doubt I'll be upgrading anytime soon. I'm gonna have some fun making the sub enclosure though, so it isn't all bad. I figure if I can design something that makes a crappy setup sound pretty good, I'll have learned enough by the time I have the money to get a really nice setup, I'll be in good shape to make that sound incredible.
For the moment I'm wondering if it's just volume of the sealed enclosure that matters or if it has to be a generally regular shape (cube, tube, sphere, etc).
Old 01-29-2005, 05:02 AM
threedd97's Avatar
threedd97 threedd97 is offline
Send a message via ICQ to threedd97 Send a message via AIM to threedd97
You won't get any SQ worth worrying over the box with that sub. As for your assumption about a lot of us choosing SPL over SQ, it's quite the opposite here.
As for the box, most people make a rectangular or cubed box, but I think usually rectangular. No weird shapes or designs. It becomes difficult to measure the proper volume inside the box and makes sound travel weird in it (this is just stuff that sounds right to me, some of it I'm sure of, but the shape thing with the sound travel I'm not). Take my advice with a grain of salt, a large one.
UNOFFICAL AUDIO BRAND RATINGS
My life is composed of the worst luck known to man.
Disclaimer: My knowledge of car audio is questionable, but it usually sounds great to me.
'98 Grand Prix GT 4Dr
'06 XXX 12"
Possibly a Cadence ZRS-10
Pioneer DEH-5500MP
Old 01-29-2005, 10:34 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
shape doesn't matter in a box, only volume. The problem in making odd shapes is figuring out the volume and making it rigid (so it won't flex)
Old 01-29-2005, 10:10 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Box shape
perfect cubes are the absolute worst sound producers. The golden ratio is optimal. 1W*0.618D*1.1618H or at least that is what the myths say.
Old 01-30-2005, 12:53 AM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
Re: Box shape
Make a triangular box.
R.I.P.: My Thunderbird "Ricks 96".. 2/08/96 - 1/14/05.
Old 01-30-2005, 01:48 AM
Audio Guy
ummm ... if it were a triangle, it wouldn't really be a "box" ..... but it would be an interesting looking enclosure Sometimes a cube can have standing waves, they are generally avoided
Old 01-30-2005, 04:43 AM
threedd97's Avatar
Re: Box shape
So I was 50% accurate with my post, I'm catching on and learning .
'06 XXX 12"
Pioneer DEH-5500MP
Old 01-30-2005, 08:49 AM
Diceman83's Avatar
Re: Box shape
has anyone used PVC pipe in any part of their boxes before? I know it's not a usual material, but I don't like to do things the standard way. A little variaty and experimentation never hurt anyone . Because of space issues I was thinking about using some 6" diameter thick walled PVC as extensions through unused parts of my trunk. I've done a bunch of calculations, taking the thickness of 3/4" MDF and the sub, and the approximate volume of my design is 4.5 cubic feet, which is near the upper limit of the sub's sealed enclosure rating. I can add some stuffing to simulate a larger volume too. I'll work on some sketches with a picture of my trunk and post it later today. You're probably going to think I'm nuts, but like I said, I like to experiment.
Old 01-30-2005, 08:59 AM
CBFryman's Avatar
Banned
Re: Box shape
you have no idea. we used 6" Irrigation PVC to make a TL for one of thoes old audiobahn 6" woofers. Probably some of the best SQ i have heard from audiobahn. and we had good responce down to 30Hz (40Hz tuning). and we used some of their sweeping elbow's to make the curves. it worked out nice. he used 0.87kg of acoustic whool stuffing (i didnt do the calcuations, dont ask me about stuffing to change tuning, i know alot for such a youngin' but not that much) to lower the tuning frequincy and it turned out only needing like 7ft of line length.
Old 01-30-2005, 06:43 PM
Audio Guy
a 6" subwoofer ? ............... the only problem with pvc is it's not to strong and may flex with more powerful subs.
Old 01-30-2005, 09:17 PM
Diceman83's Avatar
Re: Box shape
That's what's nice about tubes... a little bracing is really easy. Just crank a couple of large hose clamps on it and it won't flex much. I'm getting pretty close to a final design, after carefully measuring the inside of my trunk. I don't think I'll have any pics tonight though, sorry. I was fighting with a friend's computer all afternoon.
