Old 01-28-2005, 08:02 PM
Audioray Audioray is offline
Help 1995c1500 350 5.7
Well i have been having problems its kind of hard to describe. When i am going about 45 to 50 and hit the accelerator it like there is nothing there for a minute no power that is. The rpms dont change at all though. I had some codes and figured out the the egr valve was bad and replaced it and havent got any more codes and its been a couple of days now but the problem is still there actually seems to be happing more and more frequent. I have replaced the spark plugs, fuel filter, air filter, pcv valve, egr valve and its still doing it. I wanted to mesure the fuel pressure but there is no test point on the fuel rail could it be fuel pressure? I have yet to check my distributor cap and rotor could it be this? Any help please!!!!!!!!!!!!!!!!
Old 01-28-2005, 10:43 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Help 1995c1500 350 5.7
It could be the fuel delivery. When you say "there is nothing there for a minute", how long is it actually? Until it downshifts?
I'd reccomend buying a repair manual for your truck. It should tell you where you can check the fuel pressure, and will have a troubleshooting section.
Old 01-28-2005, 11:43 PM
Re: Re: Help 1995c1500 350 5.7
I would like to by a manual but i just cant afford it right now normaly something like this and i just would take it some where but i am really trying to save some cash. its not really a minute its maybe 1 to 2 secs tops then its fine. Any more advice?
Old 01-29-2005, 09:57 AM
Re: Re: Re: Help 1995c1500 350 5.7
Does anyone know where to test the fuel pressure??????
Old 01-29-2005, 02:15 PM
J-Ri's Avatar
Check on the fuel pressure regulator. If you still can't find it, disconnect the hose and hook the fuel pressure guage to it.
Also, check for vacuum leaks.
Old 01-30-2005, 03:11 PM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
A Haynes or Chilton's manual only cost $17 to $20. If you can't afford that, then how can you afford the gas your wasting by trying to get your truck to shit n' get?
