Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 01-28-2005, 07:46 PM
bn2wild bn2wild is offline
1978 excessive heating problems
I too have a 78 with heating problems.
It can get in excess of 220. Not good. Replaced thermostat, heavy duty clutch fan, rodded radiator
At one point, I replaced the foam stripping all around the radiator. It seemed to help substantially, but the foam doesn't stay in place.
The temp inside the cabin is always too hot around my legs.
ANY OTHER IDEAS?
Old 02-07-2005, 12:57 AM
Big Dan58 Big Dan58 is offline
Send a message via Yahoo to Big Dan58
Re: 1978 excessive heating problems
Your Cat / Converter may be starting to plug up. They will get extremely hot inside the car especially around the transmission area.
Old 02-23-2005, 12:00 PM
melton2669 melton2669 is offline
I had the same proble on my 78 and did the same things..switched to a 185 thermostat and used a 50/50 water antifreeze solution..still runs about 200 at high speed but stays below that at a slower speed..
melton2669
Old 03-05-2005, 03:59 PM
33Chev 33Chev is offline
samething
Have a 79 (L48) it kept getting hot around 220 under load...
replaced the thermostat, water pump, radiator, fan, insulated the sides of the radiator to increae air flow, finally took the engine out and rebuilt it...nothing changed..still showed 220 under load.
In the end...it was just the tempurature gauge! Seems the temp gauge problem is common in the 1978/79 range.
