Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 01-28-2005, 06:32 PM
nissan180 nissan180 is offline
Send a message via AIM to nissan180 Send a message via Yahoo to nissan180
SR Started!(Stalls after couple seconds)
I just got my Redtop SR to start in my 240. It then idles at just under 1000rpm and then slowly it stalls out)
What could be the cause of this?
Thanks
Old 01-28-2005, 06:35 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: SR Started!(Stalls after couple seconds)
injectors/fuel pump possibly.. check your alternator and distributor too.. more details pls
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 01-28-2005, 08:03 PM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
just Maybe
You might need the clutch in ...or more gas...
Old 01-29-2005, 10:54 AM
SHIFT_KA24DE's Avatar
SHIFT_KA24DE SHIFT_KA24DE is offline
you might provide a little more details then that... if we could find the exact problem from that... we'd be millionares...
Old 01-29-2005, 11:23 AM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
Vacume lines ??? more info plz...
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 01-29-2005, 01:56 PM
ok the vacuum lines for my SR are as follows: One of the lines(larger one) starts from top of throttle body and goes to the HKS BOV. The smaller top line goes to the Fuel pressure regulator. The 3rd line goes to the igniter chip and I have a T so it connects both lines that originate from the igniter chip. Could it be the throttle position sensor?
I am not using the Charcoal canister if that helps. Also recently my HKS BOV shot out Oil. and my engine smells like burnt pancakes
Old 01-29-2005, 04:42 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
Your BOV threw oil?? lolllll
Old 01-29-2005, 11:51 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
BOV threw oil? Pull off one of the intercooler pipes and check for oil in them. If this is the case, then the turbocharger's oil seals are bad. Also check the oil level of your engine. If overfilled, then the oil may be backing up in the drain line. Also try spinning the compressor wheel by hand. It should spin freely. If not, bearing failure is the cause. If this is the case, consider having the turbocharger rebuilt or buying a new unit.
As for the stalling, the problems above may be relevent, but more than likely not the cause. Consider the fuel system and ignition system as suspects. Check compression as well.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 01-30-2005, 12:29 PM
what is the idle???
E.K.
Old 01-30-2005, 03:33 PM
Re: Re: SR Started!(Stalls after couple seconds)
Originally Posted by AWDSR20
what is the idle???
it idles at about 900
Old 01-30-2005, 03:41 PM
also when I got my SR harness back(modified) it did not have a male plug that matched up with the SR throttle position sensor female side. It was a small brown plug that wasnt even close to matching. We cut that off and have replaced that with the KA male throttle position sensor plug. has anyone else had to do this with their SR? if so what color wires do we use. Cuz there are 6 wires and I do not know which ones to use. If we did something wrong...or no one has had to use the KA TPS what did you use?
Thanks
Old 02-01-2005, 04:34 PM
240droptop 240droptop is offline
Send a message via MSN to 240droptop
Sounds alot like my car when you start up your car if you rev it a bit are you able to keep it from stalling out?
The only way to Drift is with the top down and your own rubber spray hitting you in the face
Old 02-01-2005, 05:34 PM
240SX Guy
Unplug the TPS and see if it idles then. Your car should idle without the TPS plugged in.
-Cory
12.6@122mph
