Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-28-2005, 05:25 PM
tsupple tsupple is offline
No headlights!
Hello. My lowbeam headlights are not working. Bulbs are new and fuses look good. I even changed the realy in the electrical panel under the hood. Anybody else had this happen?
Thanks.
Old 01-29-2005, 12:31 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: No headlights!
The fuses look good? Have you tested it? Is there power to the fuse? Start testing the wiring at each connection until you find one without power (starting at the battery), or one with power starting at the light socket
Old 01-29-2005, 12:32 AM
J-Ri's Avatar
Re: No headlights!
Oh, and i just assumed you checked the ground already... make sure it's nice and clean.
Old 02-08-2005, 01:23 PM
frootl00p3 frootl00p3 is offline
Send a message via AIM to frootl00p3
Re: No headlights!
Hey my headlights don't really work either. My daytime running lights work. I Think I found the prob though. The STUPID switch in the steering column. I can turn the headlight switch to parking lights and drive with DRL and the headlights come on. IF I bounce around the steering column with my headlight switch in the on position, sometimes my headlights will come on. I know there is some connection in the highbeam/lowbeam switch. I don't know what it is and I haven't gotten up the guts to fix it yet. I am big on procrastination, especially since I have figured out a way around it. BUt your wires in the HIGH beam/ Low beam / turn signal switch may have come loose or something in the steering column. May want to check there. If you fix it, let me know and the details of how you did it would be great! One trick I have learned when dealing with steering column, if you unplug battery for 1 hour it dissengages the airbag.
Thanks.
