Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-28-2005, 04:48 PM
SMarquez SMarquez is offline
Intake air temp sensor.
iI have a 1988 Camry with a 3sfe eng. I'm getting a code 24 when testing. Air intake temp sensor circuit. This seems to line up with how the car is running. Erratic cold start and idle, slow idle then dies when warm. I can't find the location of the sensor in my Haynes manual. Any help would be appreciated.
Old 01-28-2005, 09:30 PM
Strider327 Strider327 is offline
Send a message via AIM to Strider327
3sfe motors should look similar to 5sfe motors. So basically the sensor should be near the throttle body. Um, guessing underneathe the intake pipe before the airbox. Can't really miss it. Try cleaning the sensor along with the throttle body and see if you still get the code. If indeed it is damage then go buy a new air intake sensor. There might be 2 sensors for your motor, not sure.
Old 01-29-2005, 09:51 AM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
Re: Intake air temp sensor.
IAT sensor on the 5SFE is right in the air filter enclosure, on the side, above the replaceable element.
Old 01-31-2005, 04:05 PM
I think i killed the sensor with spray cleaner. It will idle with the MAF wire disconnected but won't stay running now. Off to the junkyard.
Old 02-08-2005, 05:08 PM
Replaced sensor with salvage part, no change in performance. Any ideas besides what my code scanner said?
thanks
