Old 01-28-2005, 03:32 PM
thewhiteshark thewhiteshark is offline
rough ride
I have a 93 park ave.I have owned it since new and love it.Car has every option.
I have replaced front struts and rear shocks{gts suspension}The car handles much better and is firm again on the highway however when i hit potholes or small bumps the suspension hits hard in both front and rear .Doesn't seem to have the ability to dampen sudden impacts.
Also two strange things 1}if I put the car in gear before the warning lights go off after starting the horn sounds 2}sometimes the trunk also opens.Makes me laugh but drives my wife crazy.
Thanks
Old 01-29-2005, 07:37 AM
rotaran's Avatar
rotaran rotaran is offline
Send a message via MSN to rotaran Send a message via Yahoo to rotaran Send a message via Skype™ to rotaran
Re: rough ride
2} Sounds like a problem with your trunk lock. Maybe you have to readjust the trunk opener.
Mike
1991 Buick Park Avenue
1995 Ford Fiesta
Waghaeusel/Germany
Old 01-29-2005, 09:55 AM
auto trainy auto trainy is offline
Re: rough ride
If your horn sounds the same as if you were using your remote,it just may be something in you security system,which also has your trunk release.
Old 01-29-2005, 11:54 AM
Re: rough ride
thanks rotaran.somehow when I put the car in gear,usually reverse, the relay gets the signal to activate the trunk release .do you still yhink that could be a lock adjustment.
auto trainy you could be onto something .where is the control unit for the security unit located .thanks
Old 01-29-2005, 04:14 PM
Re: rough ride
Sorry that I can't say for I haven't got a manual for that car,maybey theres someone else out there that can.
Old 01-30-2005, 09:42 AM
rotaran's Avatar
Re: rough ride
Do you have a remote control for your trunk release?
1995 Ford Fiesta
Waghaeusel/Germany
Old 01-30-2005, 03:49 PM
Re: rough ride
yes ad it works fine
Old 01-31-2005, 03:49 PM
padriver padriver is offline
You may wanna check the Remote Accessory Control (RAC) Module. This module controls all the things that are acting weird in your car. On the 94 PA, it is located at the passenger side of the dashboard, below (behind) the glove box where the relay center and the PCM are.
To the rough ride: I experience the same thing, but the shocks on my car are not new. Please post if you find a solution. I considered using standard non-GTS struts/shocks to soften the ride but I'm not sure if this is gonna work. I'm also not sure if it's just the struts that are different with GTS, I guess the springs might be different also. Maybe someone has more information, please post, I'd really appreciate it.
Old 01-31-2005, 09:48 PM
Re: rough ride
it almost feels as if something is loose maybe ball joints or contro arm or sway bar???
Old 02-03-2005, 05:51 AM
deadring deadring is offline
Re: rough ride
from what i've heard, it's not the same springs in the back for the GTS and the normal suspension. just like the dynaride suspension, which i have, the shocks are soft ALOT.. that why it relies on the air shocks to support a bit of the weight...and the air shocks are 900 $ cdn at the dealer.. but i found that a shop that sells equivalent for 30$ more than a normal shock..
your best bet is getting the GTA springs as well.. the reason the car is great on the highway might be because of the sway bars if you have any... the dynaride suspension has some bigs ones as well as a strut bar under the hood.
hows the cornering?
Deadring
89' corolla ...200 000 miles on original engine, tranny,clutch and paint...and no rust... try that with a neon...
00' kawasaki zx-9 with micron exaust and K&N filter ( my baby)
Old 02-04-2005, 10:44 AM
I have the grand touring suspension .The highway ride and the cornering for the big beast is close to what it was as new.only has 120,000 miles.The problem I am trying to figure out is that after replaceing shocks and struts the ride came back but when hitting potholes or sharp raises in the road not dips,the suspension seems to almost be loose and hits hard????Thats the best I can explain it .Just doesn't have the ability to absorb the impact.????
Old 02-18-2005, 01:55 PM
straitfam straitfam is offline
Re: rough ride
I had the same trunk/horn gremlins and a new RAC module solved them, as a couple guys have mentioned.
As for the suspension, check your tire pressure and only put the Buick mfr max on the door/trunk placard (30/32 psi?) and be sure you are using a quality guage. Next, I'd have to ask what kind of shocks did you put on your car? I have had extremely good luck with Monroe Sensa-Tracs because they are smooth when you want them to be, but they have pretty good control over dips and humps -- better than factory Delco units or whatever.
