Camry V6 1997
I really need help!
THis is Camry V6 1997 110,000. I am only here in USA by myself and I don't know any good mechanic. so please help! I took my car to first mechanic because I thought power steering leak. I saw couple of drips on the drive way. He told me that there are leaks all over and I need to replace: P/s rack, P/s pump, valve cover gasket, crankshaft seal, camshaft seal.. total cost is $950-1000 and he said all belts are craked!....$700 to fix I checked service record from previous owner. He did the timing belt at 85,000 mile, but I don't think replace water pump and other things. I took my car to second mechanic. He said that P/S is not a big deal, but he think something might be leaking under timing belt. He suggest me to change valve cover gasket, crankshaft seal, camshaft seal, timing belt+ other bets + water pump + start plug for about $900 I am so confused and really need help. Thank you very much. |
Re: Camry V6 1997
Here's my opinion - Figure out the source of the oil leak. If it is the timing cover area, put up with the leak from there until it is time to replace the timing belt again. Then replace what the second mechanic said to replace, except for the valve cover gasket.
If the leak is coming from the valve cover gasket and not the timing cover area, then forget the rest and just replace the valve cover gasket. Before you do, torque down the bolts that seal the valve cover gasket and see if that solves the problem. It is possible the bolts have vibrated loose or the gasket has shrunk. |
Re: Camry V6 1997
My camry has 200 K and I have never changed the water pump. I'll probably do it in my next (third) T belt change at 260-270 K. Regarding P/S get a 60 c syringe or anything that allows you to suck as much s/p fluid from the reservoir and replace your p/s fluid and add one of those p/s leak stoppers (lukas or whatever). Good luck |
Re: Re: Camry V6 1997
You can also put a cap full of DOT 3 brake fluid in the power steering pump. That will swell up the gaskets.
Cap full=small amount, dont put too much, tablespoon approx |
At what milage did you do the first timing belt change on your Camry? Here is my story: I drive 1997 Camry V6 and the milage is about 78K. I know I've to change the timing belt but haven't made up my mind just yet... |
Re: Re: Re: Camry V6 1997
Re: Re: Re: Re: Camry V6 1997
Thank you so much... I spoke to a mechanic and he gave me a quote for the TB change of $600. Does it seem excessive or sounds ok? I'm in NYC so the prices may fluctuate. Thanks |
Re: Camry V6 1997
You can get an estimate of the cost you can expect by selecting your car and the maintenance interval from the following site:
http://www.edmunds.com/maintenance/M...g.feature..4.* |
Re: Camry V6 1997
Normally, they replace the accessory belts and the water pump along with the timing belt. Not too bad if that's the case. Get a written estimate with all the details and then make a decision.
