Question about IAC Valve
I have a 95 Cavi and it won't start unless my foot's on the gas. I cleaned the IAC valve and put it back on. I noticed that it was very difficult to move the valve, even after I cleaned it. Is it supposed to move freely? I did not take the throttle body off and clean it. I figured I'd do that next. I priced an IAC valve, but I want to make sure there's nothing else I need to do before I purchase it.
Re: Throttle Body, or IAC?
Have you check all the fuel delivery components before that? i.e. your fuel filter could be clogged, a clogged injector, fuel pump... ya know what i mean?
Please don't PM me with your J-body Issues. Post appropriately in the forums, and I will toss my opinion in your thread if I have anything to help. - Thanks! 2006 Chevrolet Trailblazer 2010 Glastron GT 205XL |
You are not supposed to move the IAC at all. rotation is okay but the in and out movement will throw it out of adjustment. You will need to do a relearn/reset proceedure. Get a Haynes manual or do a search here for details. As for the hard starting try a good cleaning of the throttle body and test the TPS while you are in there. Good Luck.
![]() Yes, I am retarded. |
Re: Re: Throttle Body, or IAC?
At first, I thought it just wasn't firing. So I changed the spark plugs. I didn't check the fuel filter mainly because with my past experiences, that would be a problem if the car stalled or sputtered. So far, that hasn't been the case. In this case, the car only gives me trouble upon ignition. Once I do get the car started, she runs perfect. I have not checked the injectors or fuel pump mainly because the problem does not persist after the car has been started. |
Re: Re: Re: Throttle Body, or IAC?
It's all IAC then. If you TB is gummed up around the IAC holes it wont work good as air cannot pass through freely!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come 'Never forget Grasshopper, Not speed, smile!' |
Re: Re: Re: Re: Throttle Body, or IAC?
Could be stuck open injectors. putting your foot to the floor puts the car in "clear fllod" mode killing fuel delivery.
