Go Back   Automotive Forums Car Chat > Honda > Locations (USA, Canada, Asia, etc...) > Europe
Europe England, Holland, Denmark, Germany, etc...
Old 03-14-2002, 02:05 AM
Fightin'Irish's Avatar
Fightin'Irish Fightin'Irish is offline
Which spring should have more coils?
Does anybody know which spring should have more coils (stronger) - the front or the rear? I recently got a set of lowering springs fitted and even though the front is lowered, the rear is sitting alot further down. I'm wondering if they were put in back to front? The rear spring has about 7/8 coils all evenly spaced, whereas the front has about 13 coils with the coils at the bottom evenly spaced and at then closer at the top? I cant tell from looking at them which is longer but I would think the front?
Any ideas?
Politeness aside, it is my observation that the best reason for not staring hungrily at the breasts of complete strangers is that they'll never smile at you unexpectedly if you do.
Old 03-14-2002, 03:16 AM
Goosse's Avatar
Goosse Goosse is offline
Send a message via AIM to Goosse
I have the same problem. I also have the idea the front is sitting higher then the rear (but I haven't counted the coils yet). How do you measure that your car is higher in the front, do you measure the wheel gap or the distance from the ground to the bumper? Cause if you measure the wheelgap, your front fenders/wheel wels are bigger then your rear ones, so you can have a perfect level drop, but it seems that your front is higher because of a bigger wheelgap.
Old 03-14-2002, 03:23 AM
I haven't measured yet - I'm just going by eye
Maybe it's just that the rear looks so low that it makes the front look high? To me, the stronger spring (more coils) should be in the front (which it is in mine) as the front of the car is heavier - but it just doesn't look even!
Old 03-14-2002, 05:25 AM
I just rang the Cobra guy's in Holland - very nice people and very helpful!
They reckon that the springs in the front are for a Vti/Si model which has a heavier engine. They told me to cut one or two coils off and that this would not affect the tension of the spring. They said I could easily take 40mm off the spring with no problems , as the coils on the top of the spring (very close to each other) are only there for the ride height and don't have any function other than that.
Old 03-14-2002, 08:04 AM
Goosse's Avatar
Is this for every spring, or just for the Cobra's?
Old 03-14-2002, 09:10 AM
I'm not too sure - but I would guess that if your springs have 4 or 5 coils sitting on top of each other, then it would be safe enough to remove one or two
Old 03-14-2002, 10:40 AM
Veetec's Avatar
Veetec Veetec is offline
Send a message via ICQ to Veetec Send a message via AIM to Veetec
Please donīt cut the springs!!! Send them back and try to get the right ones for your car. Maybe the tension wonīt be affected but the spring rates and stuff like that will be different than before. Iīve never heard that cutting springs is a good idea though.
Old 03-14-2002, 10:54 AM
Kohhal's Avatar
Kohhal Kohhal is offline
You're asking for trouble cutting springs, anyone on here will tell you that it's definetly a bad idea. It can and probably will have serious effects on the ride of your car. Send them back and get the correct ones, it's better to do it right, no regrets then.
Old 03-17-2002, 10:26 AM
Predator's Avatar
Predator Predator is offline
Send a message via ICQ to Predator
It is a real bad idea to just cut a little! The cars behavior will change drastically .If all went fine then it wont affect the cars behavior very strong but if it goes the way I know ull drive into a corner and loose completely control over ur car- so just dont do this, the risk is much too high!!
play da game for fun not fame
what for idiots... theyre discussing about a law were u have to switch on the lights the whole day but when u switch on the fog lights without fog u have to pay for this 'criminal act'...
ZOMTEC rulez!!!
Old 03-19-2002, 08:19 AM
They are the correct ones!
What they told me is that they only make one type of spring for a Civic, whether it's a Vtec or not. There are 4 coils at the top that are 'closed' when fitted. These only act as a 'spacer' to give the ride height. They told me I can remove one or two coils (to a max of 40mm) and that this will not affect the load or the tension of the spring.
Old 03-19-2002, 10:01 AM
Veetec's Avatar
Please believe us and DONīT cut the springs! Try to get your money back and then buy some brand springs like H&R, Eibach, Neuspeed, ......
Old 03-20-2002, 03:07 AM
Predator's Avatar
Well if there is no other way then cutting this springs just send them back and get other springs!!!!! BUT DONT CUT THEM!!!!!
ZOMTEC rulez!!!
Old 03-20-2002, 03:40 AM
Right - so I'm not going to cut them!
These are installed in my car already, so I doubt they will take them back (markings from spring compresser etc.). Someone on another forum reccomended using spring clamps? I'm not too sure about this either - any ideas?
The springs are only going to be in my car for a while (until I have enough money to buy coil-overs), so I might just live with it for a while
Old 03-20-2002, 07:41 AM
Veetec's Avatar
I doubt that too but I would try it anyways because at the end itīs their "fault" and not yours! Or try to sell them again and get new ones then. This stuff would really piss me off!!
Old 03-20-2002, 07:55 AM
Tell me about it!
By the way, does anyone know if the rear springs in a Coupe are the same as the rear springs in a Hatch?
Also, is it possible that the suspension in my car (96) is actually a '95 spec suspension? Or are they the same?
