Old 01-28-2005, 10:29 AM
point_man8 point_man8 is offline
Heating core is plugged not allowing enough air thru
Either the blend door is leaking/not closing fully against the cold air inlet, or the core is plugged not allowing enough air thru it.
any idea how to fix either of these
Old 01-29-2005, 04:33 AM
FORDTRACMAN FORDTRACMAN is offline
Re: Heating core is plugged not allowing enough air thru
Point-------
After the engine is fully warm,feel both heater hoses.If both are hot and feel about the same heater core is usually not the fault.
Old 01-29-2005, 09:05 AM
Re: Re: Heating core is plugged not allowing enough air thru
Originally Posted by FORDTRACMAN
Point-------
okay i will try that i know they are warm should they get real hot thanks for the reply
Old 01-31-2005, 09:24 AM
andy2005 andy2005 is offline
Re: Re: Re: Heating core is plugged not allowing enough air thru
You could try flushing the heater core.
Old 01-31-2005, 08:27 PM
timex129 timex129 is offline
Pressure
If your cooling system is open to the air, your coolant won't heat up enough to do much good. I suggest that you test your cooling system along with your rad cap. It happens alot on our military vehicles.
Old 02-03-2005, 08:06 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Your director / control doors could be stuck. It's been known to happen. Crawl underneath there, get a good luck, and make sure that when you turn the knob the director doors actually move (not sure if you can see them on your vehicle)
Old 02-06-2005, 09:29 PM
arden1963 arden1963 is offline
make sure the fan is working right
when they start going they slow dowm and dont put the volume of air over the core like when they were new
