Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 01-28-2005, 08:37 AM
03LTZ 03LTZ is offline
2002 - 2005 Envoy Outside dimming mirrors
I just picked up a used 2002 Envoy which has outside dimming mirrors...... However, I noticed the driver's side dims, but the passenger side does not......
My question to all, is should they both dim? Or is it only noticable to the passenger sitting in the passenger seat?? (Which would be kinda dumb........)
Thanks in advance.
03LTZ
Old 01-28-2005, 12:23 PM
G-Money G-Money is offline
Thumbs up Re: 2002 - 2005 Envoy Outside dimming mirrors
The only mirror that is suppose to dimm is the drive side and the rearview mirror only. Everything is fine.
Thanks in advance.
03LTZ
Old 01-28-2005, 02:18 PM
Re: Re: 2002 - 2005 Envoy Outside dimming mirrors
Whew........ Dodged another bullet.... Thanks for the research......
03LTZ
Old 02-01-2005, 11:11 PM
JAUSTIN JAUSTIN is offline
Re: Re: Re: 2002 - 2005 Envoy Outside dimming mirrors
I have a 2002 Envoy SLT and recently experienced the same phenomenon with the outside rearview mirrors. The original brochure for the 2002 Envoy states “Light-sensitive outside rearview mirrors.” There is a special line for the “Light-sensitive inside rearview mirror with compass.” I had my dealer look at both mirrors and they indicated that both were working as designed. However, I still notice that the driver’s side mirror will change from fully reflective to nearly dark green while the passenger’s side mirror remains fully reflective. I have an extended warranty and would like to get the passenger’s side mirror repaired if it is indeed broken. I would assume that if both mirrors are dimming, there should be a light sensor for each; presumably built into the mirror. Is there a single light sensor? I am getting conflicting information from the brochure, the previous post, and my dealer. Does anyone know where I can find a concrete answer? Has anyone removed the mirror? I would appreciate any help in maintaining my limited sanity.
Old 02-02-2005, 12:12 AM
Re: Re: Re: Re: 2002 - 2005 Envoy Outside dimming mirrors
Jaustin
My build sheet also says "D25-Light Sensitive HTD, PWR OSRV Mirrors", however on page 2-57 of the owners manual it states: "Electrochromic Rearview Outside Mirror with Curb View Assist (If Equipped) If your vehicle has this feature, the driver's outside mirror will adjust for the glare of the headlamps behind you."
So I'm guessing, that the driver's side mirror is the only one that should be dimming....... They should remove the "s" from "mirrors" in the brochure and the build sheet...........
Keep me posted if you hear anything different........
03LTZ
