I have a '99 Isuzu Rodeo LS, I was hoping you guys can help me out.
I want this SUV to pull from both wheels in the back. Reason being is that I'm in a bet with my friend to see who can make their Rodeo the fastest, and I want the most traction off of the line. Now, is it possible to swap out the complete rear end or would i have problems with the driveshaft? Is there a diff lock that i can mate to my diff or not? Any other suggestions are appreciated. Thanks. |
Re: Diff Lock or LSD on '99 2wd LS???
I think if you want to make you truck faster, you are going to want a lot more then a locked up diffy.
how about a super charger? http://www.azwildfire.com/isuzu/supercharger.htm ![]() link to a Rodeo forsale with a super charger (51K, 1998) for 6500.00 Looks like a deal!
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
An already superchargered Rodeo would be nice(and thats a pretty good price), but i was actually thinking of doing all the work myself. The locked up diff is just my starting point.
The motor i will get into after i finish tranny and suspension. Is that a s/c kit they sell, or is that custom work? |
No doubt a SC is the only way to go for max hp! Robert28, you may already have a limited slip (posi) rear end in your rodeo. If your option code tag on the firewall lists a "G80" code, you have a dana posi rear end diff.
G/luck Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
If you are 2wd, you won't have Limited slip.
The SC is a bolt-on kit (cost about 3k). http://www.darlington-offroad.com/it...2&PRID=1347982 here is a locker: http://www.darlington-offroad.com/it...96&PRID=809404 If you want to be quick, reduce your wight (loose the seats, door panels, spair tire and so on). what is your plan for tranny mods?
Re: Re: Diff Lock or LSD on '99 2wd LS???
Thanks for the link on the s/c. i have already removed everything from the truck except for the dash, and had custom brackets made for some bucket racing seats...they weigh 10 pounds a piece. As for the tranny, i havent started my research on any available products or cross referencing part numbers, but my plan is to install a different stall and then worry about reinforcing it when it gives out. |
photos? time slips?
Its not in running condition yet, so no timeslips...hopefully i can have this baby up and running by summer. Just a thought...do you think these motors can handle some juice? |
NO2? I'm sure the engine could take a 50-75 hit, but the weakest link is the tranny.
I think the 2005 Rodeo, has a non-GM tranny (toyota maybe?). good link same basic engine: http://www.vehicross.info/forums/sho...ight=time+slip
Where is the firewall so I can see if my 2001 4x4 3.2L has limited slip?
Standing in front of the vehicle with the hood open looking toward the engine, you should see the options tag somewhere on said firewall, right below the windshield. On mine, it's on the driver side, but look all the way across. The code you will look for is G80. Steve |
btt
photos?
btt
photos?
btt photos?
