LED Wiring
Last Night I put in these 2 little LED lights from my local Peterbilt dealer. Picked them up for 10 bucks a peice and they work pretty good. My original plan was to pull the fog light fuse light out stick the wires in and stick the fuse back in so the wires would stay. But when I pull the fuse out with the wires in, the LEDs light up but when I put the fuse back in the LEDs shut off and the Fog Lights turn on. Why is this doing this and where else can I wire this so everything to work. Im looking for a spot near the dash hopefully in the fuse panel
Re: LED Wiring
Just a guess, but a LED requires more than 0.7 volts to work, and electron's will take the path of least resistance.
I would try running a seperate circuit - don't forget a resister if its not built in. |
Where would i hook this up? There is only 3 little bulbs in this little box. its kind of shaped like an home plate with the pointed end cut off. Can I stick wires in a fuse box and pinch them with a fuse. Is it possilbe to out a bigger fuse in a #10 fuse??
Re: LED Wiring
Try putting the positive lead in the fuse, and ground the negative lead.
Re: LED Wiring
first what year
second if your car is 00 or up I think I dont excatly know what years but all the new ones have 12 volts running through the fuse panels at all times. u need a good power source um, do not put it to the fuses under the hood. put it to one of the small fuses with a toggle switch |
its a 2003 GT. Isnt it bad to stick wires in a fuse panel and pinch the wires in it with a fuse? Thats what I heard after I put the things in
Re: LED Wiring
