Old 01-27-2005, 11:41 PM
big_sam_2004 big_sam_2004 is offline
timing belt
ok, so im still looking at that 91 stealth by my house, so a report on msn autos sez that these cars had timing belt isues, and if it fails whilke youre driving, the valves are damages and repairs go well into the thousands..... so is this true and what kinds of problems have you had?
Old 01-28-2005, 03:33 AM
6g72tt 6g72tt is offline
that shit happend to my stealth turbo one day i was on my wey home when suddenly the car died on me when i got it to the mechanic a screw broke and got the timing belt off it and had to replaced valves, head, piston, crankshaft i rebuilt the engine completely
Old 01-28-2005, 03:52 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: timing belt
As long as you replace it at 60k miles as recomended by the factory most cars are generally fine. However, if something get into the belt enought to skip some teeth, or if the belt breaks it will mess up your valves, as with any interferience(sp?) engine.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 01-28-2005, 07:49 AM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
A broken timming belt will mess up the heads on any car though, not just the 3s. and no its bullcrap, 3s do not have issues with the timing belt as long as you change it at it recomended intervals. that article was probably written by someone who thinks all cars use chaindrive and thought the 3000GT/Stealth was the first ever to incorporate belt drive!
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 01-28-2005, 08:41 AM
G35turbo G35turbo is offline
Re: timing belt
I agree with Musashi3000GT as long as you do your 60k mile tune up, I never heard that they had a problem with there time in belt if if they did there 60k mile tune up.
Old 01-28-2005, 12:31 PM
thanx, im alot clearer on this now, ok so since the car has 70k on it, im wondering has it been replaced yet hmmmmmmmm, ill find out tho
Old 01-28-2005, 06:49 PM
Getsum3kgtsl Getsum3kgtsl is offline
Re: timing belt
Yeah I finally got mine changed. It was a disaster waiting to happen. I got the car at 98k miles and don't think the timing belt was changed.I took it to pepboys, but they couldn't do it cuz they didn't have the tool to open it up, so I took it to the dealer at 138k and got it replaced. I still can't go to the bathroom cuz they didn't even lubricate me first. Timing belt, tensioner, water pump and thermostat=953
Old 01-28-2005, 06:59 PM
Re: timing belt
Thats about rigth for labor and parts to do the job.
Old 01-28-2005, 07:23 PM
Re: timing belt
It was actually more, but I told them I wasn't going to spend a grand, so they gave me a 10% discount. Well.....I guess they did give me a little KY jelly.
Old 01-28-2005, 09:59 PM
Hotshot8792 Hotshot8792 is offline
usually you can just pull of the timing belt cover pretty easily and see if the timing belt is starting to wear down.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 01-29-2005, 12:01 PM
sLADe781 sLADe781 is offline
Re: timing belt
How? And what do we look for when inspecting it?
Old 01-30-2005, 12:39 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Re: timing belt
there are screws holding the timing belt cover on...so remove the screws.
what to look for? CRACKS
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-30-2005, 12:47 AM
Linebckr49's Avatar
Re: Re: timing belt
Originally Posted by Getsum3kgtsl
I took it to pepboys, but they couldn't do it cuz they didn't have the tool to open it up.
open it up? open what up? Sounds to me like a bunch of BS. but IMO, i wouldn't take your car to PepBoys. they'll just do a shitty job, guaranteed. [hey, that could be their new slogan; sounds good, and has a ring to it!]
Perhaps they needed a spanner wrench to get the crank pulley off. but that's crap b/c you don't need one: either the impact wrench method or a 'breaker bar&crank the engine' method will work. but putting the pulley back on is the trick!
WOW! that does sound about right, but crap man, that's a WHOLE lot of money just for a tune-up! on american (easy) cars, ya just loosen the tensioner, replace the belt, tighten the tensioner. 30 min job!
93 3000GT base
