Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 01-27-2005, 10:29 PM
homeskillet43 homeskillet43 is offline
Send a message via AIM to homeskillet43
I am having problems with my air ride
I have a 1995 Lincoln Continental, the problem I am having is as follows. My pump seems not to turn on, the control module is good, the height sensors are good, the fuse under the hood is good, and the pump itself works. I know the control module is good, because when i take power from the battery to the pump, the front bags will go up, then the rear bags with go up. I know the height sensors are working as well. You can take direct power from the battery to the pump, and the pump works. The air bags are good as well. They say there is a relay for the suspension, is it different from the fuse under the hood. If you have any solutions please contact me as soon as possible, because I really not trying to get coil springs for my car, I love the air ride? You can contact me via aol instant messaging screen name is homeskillet43, and you can contact me through email at, [email protected].
Old 01-28-2005, 06:16 PM
Towncar's Avatar
Towncar Towncar is offline
Make sure the override switch in the trunk is'nt shut off.
-Steven
1996 Town Car, Cartier
Old 01-29-2005, 04:11 AM
Re: I am having problems with my air ride
The air bag switch in the trunk is turned to the "on" position.
Old 02-01-2005, 06:02 PM
STINKINLINCOLN's Avatar
STINKINLINCOLN STINKINLINCOLN is offline
Send a message via AIM to STINKINLINCOLN Send a message via MSN to STINKINLINCOLN Send a message via Yahoo to STINKINLINCOLN
Homeskillet I have a 93 lincoln that does the same thing if you read back on my threads you will see I am still have the same problem I have spend over 3,500.00 dollars and over 300 hours of my own time to try and fixs this problem but with no luck I have replace everthing and still does not work I am going to be bringing the car back to the shop o friday if they find out what is wrong with it I will let you know as soon as I can
93" LINCOLN CONTINENTAL
69" BUICK RIVIERA
1988 MAZDA B2200NEEDS HELP
http://www.geocities.com/jjbannon81/69RIVIERA.html
1999 OLD ALERO
Old 12-18-2008, 08:39 AM
NoTiiMe4LaMez NoTiiMe4LaMez is offline
i am having serious problems trying to sign on to aim !
feel free to write to me , though.
drzfyn3stlady24
= ) ps. im new to this ! HELP
Old 12-20-2008, 05:28 PM
Towncar's Avatar
drzfyn3stlady24
Hello *Lady24 -
Can you describe what you need in a bit more detail please.. just "POST REPLY" in this message, we will all communicate with you here.
-Steven
