Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-27-2005, 08:33 PM
HammerStriker HammerStriker is offline
'95 JGC 4.0L engine dies and won't restart for 20 min.
Hopefully you guys can help....
My jeep starts and runs fine for about 15-20 mins. then without warning dies and will not restart until completely cooled off. I replaced the fuel pump last weekend for a different problem, and it seems to be working ok. I figure it has to be some relay, but which one? Any help you guys can provide will be appreciated.
Thanks,
HS
Old 01-27-2005, 08:54 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: '95 JGC 4.0L engine dies and won't restart for 20 min.
Could be the ASD (Auto Shutdown Relay).
Or the Ignition Coil, when the Ignition coil gets hott (when it goes bad) it will shut down and not work until it cools down - just like a bad Fuel Pump.
Check for spark when the jeep shutsdown nexttime. and check to c if the Fuel Pump is kicking ON. If fuel is coming on and NO Spark the Ignition Coil would be the best bet. If no spark and no Fuel - then ASD.
Old 01-27-2005, 09:17 PM
The pump is kicking on, and during my last problem I replaced my ASD relay, so I guess I'll check my coil tomorrow.
Thanks
Old 01-27-2005, 10:28 PM
Dale Aeppli Dale Aeppli is offline
Thanks
Check for spark at the coil wire, if no spark possible crankshaft sensor dale [email protected]
Old 01-27-2005, 10:34 PM
luciouslucius luciouslucius is offline
Thanks,
HS
I had a 1989 4.0 that did the exact same thing, and it was the cps, it was mounted on the bell housing of the transmission on the drivers side up top....
Old 01-28-2005, 04:05 AM
Cam7 Cam7 is offline
Check the Cam position sensor inside the Dist. It will act like a bad coil when it gets hot and restart when it cools off.
Old 01-28-2005, 03:17 PM
Is it the "cam" shaft position sensor, or the "crank" shaft position sensor? I'm bumming rides to NAPA, so I was get the coil and sensor figuring if I don't need it, I will eventually.
Old 01-28-2005, 03:27 PM
JDPascal JDPascal is offline
The cam position sensor is in the distributor and the crank positionsensor is at the back of the engine above the flywheel.
JD
Old 01-29-2005, 02:08 PM
Is there some special trick to getting to the CPS? I've tried all morning, and i can get a wrench on it, but i don't have roon to turn it.
Old 01-29-2005, 07:59 PM
Socket and extensions - if possible
Old 01-30-2005, 04:55 PM
For those following along...
I replaced my Crankshaft Position Sensor, and it seems to have fixed my problem.
For those about to attempt the same repair...
A 1/4" Drive Flexhead Wrench with a 7/16" socket is a must!!!! I finally got to it from underneath, while reaching around the bellhousing. Also, the great guys at Jeep zip-tied the wireloom on top of the transmission. So I cut one end off of the old sensor to remove it, and routed the new one differently.
Hope this helps, and thanks for all the help.
HS
Old 01-30-2005, 05:40 PM
Sorry, HammerStricker. I guess I gave you some unusable info. I was thinking you had a 5,2L/5,2L V8.
I was not thinking of it to be a 5.0L for some reason.
