Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 01-27-2005, 07:39 PM
kxbrian kxbrian is offline
1987 rx-7. Why is the enine locked up?
if you can please help.My girlfriends cluch pedel went to the floor.I replaced the slave and the master cyl,and it works now,but i tried to start it and it seems like the motor is locked up,starter is good and battery to.I tried rocking the car in gear but engine wont move.
Old 01-28-2005, 06:33 AM
mcs mcs is offline
Send a message via MSN to mcs
Re: 1987 rx-7
so it doesnt turn?
your cars fast, but mines faster!.
Old 01-31-2005, 01:06 AM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Re: 1987 rx-7
Carbon lock? From a failing clutch system?
Thats prety odd...
1988 10th AE Edition TII
More mods then you have.
Old 02-02-2005, 06:44 PM
Autofreefindersguy Autofreefindersguy is offline
Banned
Re: 1987 rx-7
Is it stuck in gear?
Old 02-07-2005, 06:03 PM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
Re: 1987 rx-7
looks like you've broke smething in the bellhousing, check out if you can remove the tranny and see in there..
Old 02-10-2005, 06:01 PM
lilsk8erpimp lilsk8erpimp is offline
Re: 1987 rx-7. Why is the enine locked up?
have you checked the nuetral safety switch? its a rectangular like thing at the top of the clutch pedal...behind it...have someone push that all the way in and then you turn the car...it might be the switch
Old 02-20-2005, 10:47 PM
WRC85 WRC85 is offline
I had a similar problem, but it happened while i was driving down the freeway, i got off an exit and all the sudden i had no clutch, it still felt the same, but it wouldn't disengage. I knew i had a little problem with my master cylinder, so after much problems rebuilt that in a gas station parking lot, and bled it. the problem happened once more, but then quit, was this a fluke deal or will it return to haunt me? sorry for the long post
