Old 01-27-2005, 06:01 PM
kazmaniandevil05 kazmaniandevil05 is offline
Send a message via AIM to kazmaniandevil05
AutoTrans Interceptor and MAF Translator
Hi,
I am considering buying the AutoTrans Interceptor and MAF Translator mostly because i found a great deal for them. I currently have a 2000 GTP with an SLP cat-back, cai, and 3.4 inch pulley. Are these mods worth it and will they do much for my performance or are they just a waste of money?
Here are links to both
MAF Translator :
http://www.3800performance.com/Merch...roduct_Count=2
AutoTrans Interceptor:
http://www.pfyc.com/store/merchant.m...y_Code=GPUNDER
Thanks in advance
Old 01-27-2005, 06:46 PM
bcreverend's Avatar
bcreverend bcreverend is offline
your better off going here: http://www.intense-racing.com and buying a reprogrammed pcm that will do basicly the same thing as the trans interceptor. if you want to control the timing with an maf you should get the option on the pcm with the timetables to do so...
silver 99 grand prix gtp with Intense standard pcm, 3.4 intense modular pulley, oversized supercharger idler pulley, zzp underdrive water pulley, zzp overdrive alternator pulley, tps enhancer, open cone filter, thrasher shift kit, strut tower bar, eibach springs, autolite spark plugs, 180 degree t-stat, throttle body spacer, flowmaster catback w/U-bend delete, Rear O2 simulator, silvania headlights, xenon foglights, 40 cp reverse lights, and a custom 600 watt audio with cd changer.
