Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-27-2005, 05:24 PM
fastbuhda fastbuhda is offline
91 crown vic wont throw fire from coil
I have a problem WITH MY CROWN VIC IT WONT THROW ANY FIRE AT ALL. GOTS A NEW DIS,COIL,ROTOR AND CAP.THERES FIRE TO THE COIL BUT IT WONT FIRE. PLEASE HELP SOMEONE!!!
Old 01-27-2005, 10:30 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
is spark geting to ne of ur spark plugs?
Old 02-01-2005, 07:30 PM
jspence35 jspence35 is offline
Re: 91 crown vic wont throw fire from coil
check for pulsing ground on ground side of coil while cranking; no pulse=no spark, probably ignition module
Old 02-02-2005, 08:59 AM
radioman2002 radioman2002 is offline
If you have a 5.0 engine, the ignition module on the side of the distributor is bad. I had one that was flaky, some days it would run others it ran terrible. Of couse it had to die on the worst weather day we had, causing my dad to have to walk about 2 miles in the pouring rain off the Interstate. I belive there is even a recall for it, depending on the year of the car.(1988-91 I think)
Old 03-08-2005, 06:24 PM
HAY COBRADUDE360 NO AM NOT GETTING ANY SPARK AT ALL EVERY THING IS NEW MODULE, DIST,CAP,ROTORAND COIL STILL NO SPARK ANY INFO PLEASE REPLY THANKS A.C
Old 03-08-2005, 06:58 PM
wow wtf
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 03-08-2005, 08:35 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Check the wiring connector around the power steering pump. These were bad about corroding and the connector disintergrating. It carries all the wires that go to the coil.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-09-2005, 12:41 PM
Re: Re: 91 crown vic wont throw fire from coil
have checked all the wires running even replaced some fuse wires around that area.connect a spark checker still no fire but after i stop cranking engine a dim light flashes once. what does that mean.way2old thanks for your info much needed.fastbuhda stay cool bro
Old 03-09-2005, 12:53 PM
way2old's Avatar
TOKEN HILLBILLY
Just for giggles, start disconnecting each componet that is controlled by or sends a signal to the PCM. I have seen sensors short out and take the voltage to ground. Don't forget the cannister purge valve under the battery. Good luck.
Old 03-09-2005, 04:54 PM
THANKS BRO I'LL DO THAT LET YOU KNOW WHAT I FIND
Old 03-11-2005, 11:42 AM
Chrome_Rust Chrome_Rust is offline
your getting spark from the Coil....when the engine is turning is the distrubutorshaft turning? and did you install the rotor in under the cap?...
Old 03-14-2005, 10:30 AM
rotor is in and no am not getting fire from the coil.coil is new.help
Old 03-16-2005, 03:00 PM
RouterDude RouterDude is offline
One Item you have not replaced and these go out just as much as the module, and that is the Crank Posistion Sensor. It is located on either the left or right side on the block at about 11 or 1 O'clock position by the harmonic balancer. It is nothing more than a wire wrapped magnet that picks up a pulse every time the metal passes it, there is a plate mounted behind the damper with 4 prongs on it that set the timing. If that is bad there will not be a trigger pulse sent to the module to fire off the coil. Since you replaced the top end parts, you have eliminated another cause of no spark, that is the module inside the distributer that the module on the side plugs into.
Note, some cars have this, some dont. Some use the stator and pickup inside the distributer, some use the CPS, some use both. Another thing to do is check for codes, you can pickup a scan tool for the old fords dirt cheap. You count the pulses and pauses to read the code, or you can jumper the connector and read the check engine light the same way, but I dont remember the jumper points.
Old 03-19-2005, 12:12 PM
hay bro thanks for the info much needed and appreiated thanks.the car i have has a pick-up coil inside the dist
