Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 01-27-2005, 04:14 PM
nogocivic nogocivic is offline
Post having problems wit honda zc swap
I have a 1993 honda civic vx hatchback. the person I got the car from put a zc engine in it with the vx transmission. I am having tons of problems with it.for one it is extremely slow but the main problem is the idel when I start the car it kicks up to 2500rpm and and bounces up and down until it is warmed up then when I go downhill it cools down the engine then I am right back to the idel problem again. please help
Old 02-11-2005, 11:24 PM
derekappel derekappel is offline
Re: having problems wit honda zc swap
first what is the ecu you are using and is the zc a sohc or dohc and are are you getting any engine codes.
Old 02-12-2005, 08:19 AM
89stdzc 89stdzc is offline
Send a message via AIM to 89stdzc
i'm going to assume you're using the 1995 Dohc ZC
A) in that car it's slow period. i haven't seen anyone with that engine get any respectable speed out of it.
B) the going up and down of idle is prob. the EACV located on the intake manifold. it could be clogged (remove it spray it down with cleaner) or it could be no good (get a new one)
Old 02-12-2005, 11:52 AM
Re: Re: having problems wit honda zc swap
I am using the p75 94 ls integra ecu the zc is dohc and no the check engine light does not come on and no codes are displaying thank you for the reply get back to me thanks if you have any more ? I will be happy tto answer them
Old 02-12-2005, 12:30 PM
I think i have the vx tranny the transmission code is s-20 do you know what tranny I have 1st gear goes to 40mph 2nd gear goes to 80mph
Old 02-22-2005, 10:20 AM
alright you're tranny isn't what's causing the crazy idling... look on your air intake manifold on the back side of it is a device held on by 2 12mm bolts. and it also has 2 hoses going to it which have anti-freeze. so remove the hoses, and bolts, pull the EACV off. make sure you don't rip the rubber gasket. get some carb. cleaner or brake cleaner spray in the two holes (inside the holes you should see something that looks like a spring) just keep spraying. then put it back on and hope it's not dead.
1989 honda civic hatch Standard model Gutted
(1650 lb)
Freshly rebuilt ZC
2.5 exhaust
(2) 10lb bottles of juice
75 wet shot
lightweight crank pully
ZC tranny W/ SI final
8lb flywheel
Dual force p.p.
ACT clutch
2.5" drop
cheap tires
cheap rims
projector headlights W/matching corners
20% tint
semi-flat black paint (hotrod black)
Old 09-17-2012, 11:42 PM
dammit44 dammit44 is offline
I'm sorry but I'm a newbie but I need to know will a d16z6 fit an 01 civic lx help please
